Procedure for upgrade CUCM 6.XXX to 6.YYY
Who can advice me procedure for upgrade CUCM from version 6.XXX to 6.YYY?
Where I can read about this?
Hall of Fame Super Silver
Re: Procedure for upgrade CUCM 6.XXX to 6.YYY
Hi Chris,
This doc is okay, but it does not describe how to upgrade a cluster.
With the windows versions there was always a more or less fool-prove process (boot publisher - then you can start subcriber..".
I kind of miss that in the new docs - they just tell how to find the media (DVD or SFTP).
Cheers,Martin
Well, it's still the same idea, upgrade the Pub and then move on to the subs.
Chris
just to add to the great info from Chris
IP Telephony: ucm 5.1.3 to 6.1.2 upgrade
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40^1%40%40.2cc19e3f/2#selected_message
java
if this helps, please rate
java
www.cisco.com/go/pdi
Below is the procedure in brief:-
1. Check the CUCM Version Compatibility with the Upgrade Version.
2.Take a complete Disaster Recovery Backup of the Publisher Server using a SFTP Server that is always accessible through the Network.
3.Navigate to the OS Administration on the Publisher Server, Login to the OS Administration Page
Click on Software Upgrade -> Install/Upgrade
Use the DVD Media if you are upgrading from the DVD
If you are upgrading from the Remote File System, enter the below:
Directory /
Server x.x.x.x
User Name (SFTP/FTP Username)
User Password (SFTP/FTP Password)
Transfer Protocol:- SFTP/FTP
Click on Next
4. You should see the Upgrade File
5. Continue with the Wizard (if you would like to complete the upgrade automatically, choose to boot to upgraded Partition, else you can do a manual switchover
Settings - Version- Switch Version to boot to the Upgraded Partition).
6. Only upon booting to the upgraded partition, start the Subscriber Upgrade.
Thanks and Regards
Sriharshaa Prabhakar
Senior Consultant - Cisco Unified Communications
Network & Telecoms Group
Mannai Corporation, QSC
359
