Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Procedure to change directory numbers for Unity voicemail ports
Does anyone have a procedure to follow to change the directory numbers for the Unity voicemail ports?  I have a customer who ordered a new block of DIDs and they conflict with their current Unity port directory numbers.  We are running Unity 5.0(1) and CallManager 7.1(3).
Thanks in advance,
Kristine
Re: Procedure to change directory numbers for Unity voicemail po
Unity doesn't actually care about the DN's assigned to the ports.  So, you only need to modify this in CUCM.  So, there are 2 ways to go about this:
You can delete the existing ports and re-run the VM Port Wizard to delete and then recreate them.  This will obviously bring all of the ports out of service while you complete the wizard.  You'd want to do this during off-hours.  Once you're done, you'd want to add the ports back to the proper hunt configurations as well.  Basically, follow all of the same procedures for setting up the CUCM as you did when you first installed Unity.  The ports should re-register immediately when they are re-created.  If they don't, I'd stop/start Unity to get them to come back online.  If you have a lot of ports, I'd probably go this route.
Alternately, you can just change the DN's manually on each port and reset the port.  This takes out one port at a time as you just need to reset each port once you change the DN.
To my knowledge, there is no bulk job for this as that part is covered via the Port Wizard.
Hailey
Please rate helpful posts!
Hall of Fame Super Red
Hi Kristine,
Hope all is well
Just thinking out loud here, Unity Ports are generally in a separate
Partition/CSS like shown below;
For example, enter "VMRestrictedPT, Partition for voice mail port directory numbers."
For example, enter "VMRestrictedCSS."
This Partition is not able to be dialed by the IP phones and they are in their own Partition/Partitions
so there wouldn't actually be a conflict. An IP phone is only supposed to be able to dial the Unity
Pilot # so this would likely be the only conflict. The Pilot is always related to a DID number for remote
access so maybe this one DN can be used for the Pilot#.
If I had to change the DN's  I would re-build the integration from scratch to cover all the angles.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/integration/cucm_sccp/guide/cuintcucmskinny090.html#wp1040314
Cheers!
Rob
There you go...Rob and I are on the same page and he sent you the Integration Guide I referred to.
Thank you so much for the quick responses. I will take a look at the
Integration Guide and let you know how it goes...
Hailey,
Someone here once told me;
"Great minds think alike....and then there's us "
Cheers!
Huff
250
