01-01-2014 12:56 AM - edited 03-16-2019 09:04 PM
01-01-2014 01:08 AM
Hi Obaid,
You need to go for third party tool for locking and unlocking the IP phones.
http://www.parsec-tech.com/utility_applications.html#MarsPhoneLockUnLock
http://www.andtek.in/communications-products-lockout.html
regds,
aman
01-01-2014 01:35 AM
Do we don't have any other procedure without using a third party tool?
01-01-2014 01:47 AM
Hi Obaid,
No.
Other way around , u can use Extension Mobility where the user need to enter credentials if it solves your purpose.
regds,
aman
01-01-2014 12:46 PM
Hi Obaid,
In addition to lock using EM
disable setting access from phone configuration page so users can only access ring tones and background from setting menu
Haitham
01-01-2014 03:05 PM
Hi Obaid,
Yes, by using fac feature.
Please rate this post if helpful
01-01-2014 04:09 PM
FAC does not lock phones
01-03-2014 12:40 AM
you can try to take a look here: http://www.2ring.com/NewJuice
The feature called PhoneLock can resolve your need.
Basically, the (un)locking principle is based on CSS change and on user PIN.
HTH,
Martin
