Procedure to upgarde Cisco Communication manager business edition
abhasjain
Is the procedure & patch file required to upgrdae Cisco communication manager bussiness edition (CUCM BE) from ver 7.0 to 7.1 is different from the patch file used to upgrade CUCM 7.0 to CUCM 7.1 ?
Can only communication manager be upgraded in CUCM BE without upgrading cisco unity connection available with CUCM BE ?
AJ
Jaime Valencia
The files are the same for CUCM, CUC or CUCMBE.
In CUCMBE you upgrade the whole system, meaning CUCM+CUC
Cisco Unified Communications Operating System  Administration Guide Release 7.1(2)
Software Upgrades
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucmbe/cucos/7_1_2/iptpch7.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Please provide the link for latest file for downloading Cisco communication manager bussiness edition patch.
AJ
