08-25-2013 10:59 AM - edited 03-16-2019 07:02 PM
Does anybody know the software "Enterprise License Manager", ??
it is used to make the upgrading procedure in cucm from 8.x to 9.x , i think is a software installed in a pc, and with the credentials of the cucm you can connect to cucm and make the upgrading procedure, is this ok??
thanks.
Solved! Go to Solution.
08-27-2013 03:27 AM
Ivan, Watch this webinar... This will definately clear all the doubts..
https://supportforums.cisco.com/docs/DOC-27237
Thanks..
08-27-2013 03:55 AM
thanks a lot for your answer, all is more clear now
Regards!
