Program Phone Button
techbeckk
Ok, hopefully I am on the correct forum....
We currently have a main helpdesk number that after a few  rings, will ring over on other extentsions.  Since this number is different from the rest of the department, I would like to program a button on my phone/line so when the helpdesk line is called, the button on my phone will light up and display who is calling.  The model of phones I am looking to do this on is the Cisco 7962 and 7942.
Yes, if you want to have a new/separate DN for that.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
6 Replies 6
Jaime Valencia
And what do you use???
CUCM?? CME?? version???
java
java
Sorry, we are using Cisco Unified CM 7.1.5.
You can add another line (if there's room on the phone) as a shared line, or add it as a line group, or use your current line on a line group.
java
java
So I just programing the button as a new DN?
java
java
Created a new BLF SD and that was what I was looking for.  Thanks for setting me on the right track.
