programme 'second line' softkey as single number speed dial on 7942 (CCME)
I have a CCME (3900 V15) with 7942 phones.
Is it possible to programme one the two 'line' softkeys (the two on the right of the LCD) to achieve this?
I believe these 'lines' are referred to as ‘buttons’ in the configuration.
i'm thinking a translation pattern to achieve the tail end but I can't figure out how the force (say button 2:1001) to dial something just by pressing it so that I can Xlate it to what I want.
Any ideas?
2 ACCEPTED SOLUTIONS
Re: programme 'second line' softkey as single number speed dial
Monitor-Line Button for Speed Dial is what you want. There is a good example in the link I gave you.
ephone-dn 11
number 2311
ephone-dn 22
number 2322
ephone 1
button 1:11
ephone 2
button 1:22 2m11
Button 2 on ephone 2 if pressed will speed dial extension x2311 and monitor the status of the line as well.
Please rate helpfull answers!
Hall of Fame Super Gold
ephone-dn 11
number 2311
ephone-dn 22
number 2322
ephone 1
button 1:11
ephone 2
button 1:22 2m11
Please note that OP did not ask about monitor lines. Anyway the preferred way to "monitor" lines isn now BLF-speed dial. That has many advantages, not last the user can set edit their BLF directly from phone UI.
Use the link below to configure Speed Dial buttons on the CME platform.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmespeed.html#wp1010702
Yip - I did that. Got rejected.
Problem 1 = Call Center manager from hell
Problem 2 = Manager has seen this done before on another CMEx system!
Alternatives = 0!
ephone-dn 1
button 2:91001
/91001/ /0123456789/
going to test it now................
Problem 1 = Call Center manager from ****
Alternatives = 0!
The indication you have been given above is 100% correct: configure speed-dial button. Explain why that is not acceptable, because as it impossible to understand.
Then from the rest of your postings it seems to me you are are not familiar with CME configuration.
ephone-dn 11
number 2311
ephone-dn 22
number 2322
ephone 1
button 1:11
ephone 2
button 1:22 2m11
ephone-dn 11
number 2311
ephone-dn 22
number 2322
ephone 1
button 1:11
ephone 2
button 1:22 2m11
cheers....
My customer want one of the line buttons on the right-hand-side of the 7942 to dial 0123456789 when pressed - the end.
I'm using a call manager express system.
My customer will consider no alternatives.
ephone 1
button 1:90123456789 ??
or
button 1:91001
/1001/ /0123456789/
cheers....
As mentioned before already. Speed-dial button does exactly that, but you have not explained why that is not acceptable to your customer
No alternatives will be considered - she's seen it before and wants it on her new system - THE END!
pls come to peace with this.
Note the lower button - once pressed 01698.....ect. is dialled.
unfortunately I dont have access to the CME associated with the 7940 in thepic!!
I don't know what your issue is, but everyone on here has already explained  that, what you want to configure is a speed dial. As mentioned by Amine, below  is what you need to do.
Example:
ephone 1
mac-address 1234.5678.ABCD
button 1:2
speed-dial 1 91001 label Work
Yosh
HTH Regards, Yosh
You're not reading my request.
press line 2 (see pic) and it automatically dials 01698.........
how is this configured on a call manager express?
Hall of Fame Super Red
Hi there,
The pic looks like a Speed Dial with a label of
01698611020 I think that's all they've done here
Cheers!
Rob
"A smile relieves a heart that grieves"
- Stones
EXACTLY!
how did they make a line a speed dial?
Find the phone you want to add the speed dial to and enter "speed-dial 1 01698611020 label 01698611020"
Yosh
HTH Regards, Yosh
ephone 1
And that will produce the result exactly per the picture??
or, will it enter a speed dial in the directories menu!!!
read the question!!!
ephone 1
That will produce the result exactly per picture, as 4 (four) people have told you on this thread!
Furthemore, users can configure and edit that by thmselves from the phone !!
Read and understand the answers, and stop be assuming about others not understanding!!!
I apologise!
Alas - no button still!!
i think we're half way there - perhaps I need ...
button 2:(put something here like TeleWere perhaps!!)??
here's my config ............................
ephone-dn  77  dual-line
number 4389
label Hot Desk
description 4389
name Hot Desk
ephone  77
mac-address xxxx.xxxx.xxx
ephone-template 2
fastdial 1 901302123456 name access code
speed-dial 2 901302123456 label "TeleWare"
type 7942
button  1:77
ephone  77
ephone-template 2
speed-dial 1 901302123456 label "TeleWare"
type 7942
button  1:77
Try this speed-dial 1 901302123456 label "TeleWare"
Remove fastdial.
Configure speed-dial 1.
Reset phone.
Again; you do not need things like button 2:
Nope!
So! I dont need to perform any configuration on the button I wish to apply the change!!
I have configured this on my lab 2900/ccme and same result - nothing appears on button 2 (Line 2) - and why would it!
You are providing a speed dial config which applies to the speed dial menu under the directories button.
I think Amine Nouasri's answer might be the right direction.
i'm try to configure a line button to automatically dial a number.
somehow button 2: needs a config to manipulate it to dial a number once it is pressed.
Nope!
Really there is to say that you have a difficult attitude to deal with, even if you apologized before. Clearly, you have zero experience in configuring CME, and this is the very first time you are configuring a speed-dial, yet you have formed in your mind that for somethig to appears on button 2, you need to have a "button 2" command, and you are not believing anything else. The simple fact is that you are wrong:
On an IP phone, speed-dial entries are assigned to unused line buttons. Then, after all line buttons are used, subsequent entries are added but do not have an assigned line button. The speed-dial entry is not related to the physical button layout of the phone. Entries are assigned in order of speed-dial tag.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmespeed.html#wp1021955
The entries that appears under personal directory are fastdial, not speed-dial.
Now, check your ephone-template configuration, as it may have a custom button-layout. And if not that, you are doing something else wrong.
+5 Paolo
Yosh
HTH Regards, Yosh
+3.5!
We do use custom softkeys...
ephone-template  2
service phone ehookEnable 1
user-locale 1
softkeys idle  Redial Newcall Cfwdall Gpickup Pickup
softkeys connected  Hold Endcall Trnsfer Confrn ConfList Park
softkeys ringing  Answer
That doesn't change how speed-dial appears, so there must be something else.
Success!!
THANK YOU AMINE!!!
ephone  1
mac-address xxx.yyyy.zzzz.aaaa
type 7940
button  1:1 2m8
ephone-dn  8
number 0123456789
call-forward all 90123456789
FYI
ephone  1
mac-address xyz
fastdial 1 0123456789 name access number
blf-speed-dial 2 0123456789 label "winging_it_&_getting_caught_out"
speed-dial 1 0123456789label "only_reading_manuals&having_no_practical_experience"
Only results in 'access number' appearing in my personal speed dial nothing else - after full phone reset (cable out/in)
Happy Thurs all!!
That still does not explain why "speed-dial" does not work, as it does in the thousands of other CME's installed in the world.
Perhaps had you remove "speedial" it would have, but you gave up.
Now you have an extra DN and setting that are not necessary, Also Note the DN 8 is single line so it canot do attended transfer, also it has a different number that the original user number.
463
