Community Member
Programming phones
    Hello all,
Completely new to Cisco right now.
I've managed to stumble my way through programming phones on my network, and I'm looking for an easier way to do this.
I figured out how to copy a phone and apply it to another MAC. I'm currently programming some 7975 phones with 7916 sidecars. When I setup the first phone with all the speed dials and BLF buttons and copied it to a new phone, none of the numbers that were programmed on the sidecar or the phone itself copied over.
Is there a way to do this or am I doomed to enter all the SD's manually?
Thanks, Eric Erickson
Village of South Holland, IL
PS - if this thread is in the wrong location, please point me in the right direction - Thanks
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Programming phones
Hi Eric,
Just one note in addition to the good info from my friends
Yosh & Islam (+5 )
Instead of using "Copy" use "Super-Copy" and the lines
etc. will copy across between devices.
Cheers!
Rob
"Seek it out and ye shall find  "
- OneRepublic
Programming phones
Hi Eric
Can you just share if you have CME "router" or CUCM "server"?.
please rate all useful information
Community Member
Programming phones
Hi Islam,
I have a CUCM Server v9.1
Re: Programming phones
Hi Eric
There is no configuration required. All you have to do is connect the KEM or 7916 module  to the phone and register the phone to the CUCM. You will see KEM power up and a Cisco logo appears.
Additional speed dials/lines configured for that user will appear on the KEM, once phone is registered.If you have many phones  you can use BAT Administration Tool as the below link
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/9_1_1/ccmcfg/CUCM_BK_A34970C5_00_admin-guide-91_chapter_01100110.html
BAT will be so helpful , if you have many phones you can edit on excel file , then uploaded on the CUCM.
If you need to share any infomation , just give more details.
Please rate all useful information
Programming phones
Have you attempted to use the BAT tool? You can create a phone template to reduce the amount of information that you would need to include in the csv file. Below is a link for more information.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/9_1_1/CUCM_BK_C271A69D_00_cucm-bulk-administration-guide-91_chapter_0110.html
Yosh
HTH Regards, Yosh
Programming phones
Hi Eric,
Yosh & Islam (+5 )
Cheers!
Rob
- OneRepublic
Programming phones
Super-copy!!! I really have to get 9.1
+5 Rob you the man
Yosh
HTH Regards, Yosh
Programming phones
Hi Eric
Thanks for rating Mr/Rob  , (+5 ) for your professional information .
"SUPER COPY"  copy the device and line configuration as well like CSS, PT,etc..however when you click  "COPY" copy the device config not line one.
Thank you
please rate all useful infomation
Community Member
Programming phones
Fantastic. Thanks Rob - the Super Copy is exactly what I was looking for. Scan in the MAC, change the Directory Number and all is good. I knew it had to be something simpler than me.
Thank you very much.
  - Eric
Programming phones
Hi Eric,
You are most welcome! "Simpler than you and me both"
Cheers!
Rob
- OneRepublic
132
