09-20-2010 02:27 PM - edited 03-16-2019 12:53 AM
Hi all,
Does anyboby have any document on the pros and cons between SIP and PRI ?
I understand PRI has been around forever and SIP is a fairly new technololgy and it seems like that's where everybody is headed. What are the extra benefits with SIP ?
Thanks in advance !!! I appreciate any inputs/suggestions !!!
D.
Solved! Go to Solution.
09-21-2010 07:32 AM
Agree with the previous poster.
I'll wear my TDM hat and spout out some disadvantges of SIP over PRI now:
* ISDN is a solid standard. SIP is still new, and not all providers support all recommendations. You may likely encounter some interop quirks of some sort at some point.
* You don't have to worry about QoS out towards the cloud and voice quality issues (assuming your TDM gateway isn't across a WAN).
* Better fax support (SG3 speeds). Modem support.
* Better E911 options. Some providers have E911 solutions for SIP trunks, but be sure you check that out.
09-20-2010 11:17 PM
SIP gives you disaster recovery and scaling.
You can move DID's over to a backup/secondary location and have your phones up and running. (as long as u have a backup gateway and subscriber at the backup site)
You can also terminate DID's from any area code so that you can have a centralized location to bring in all DID's. (instead of ordering local DID circuits at remote sites)
cost savings, disaster recovery and simplified scaling are really its main pluses.
09-21-2010 09:28 AM
Just a bit of a follow up. My operations is on PRI service. My service provider offers a feature called "Trunk Busy Overflow." Like the name implies, if the one PRI trunk is busy calls will roll to another PRI we own. If I talk to the right person with the service provider I found I can have multiple PRI connections roll over to the backup site.
09-21-2010 07:32 AM
09-22-2010 10:04 AM
thanks gentlemen for your resposne !!! very helpful !!!
I am still iffy about SIP and not sure if the cost saving is really there and more than likely I will run into some sort of interop quirks as Steven mentioned in his response. I currently running with 4 PRIs (2 in Ca and 2 Tx) and disaster recovery worked great for me, all calls come in to Ca first and then overflow to Tx if Ca is busy or offline.
Thanks all !!!
D.
