PSTN access code when centralized deployment with CCM
gmichel08
I've got a centralized deployment with CCM6 and two sites. I used two H.323 gateways and set the PSTN access code to 9. I defined my route pattern and put my gateways in a route list. My problem is that I've got most of the calls from site B routed the site A gateway. I've thought of two access codes but what if i've got 100 sites to deal with.
Please advice,
sysjes
Define your route groups
SiteA_RG = RTRA
SiteB_RG = RTRB
Define your route list
SiteA_RL = SiteA_RG
SiteB_RL = SiteB_RG
SiteA_RL = SiteA_RG, SiteB_RG
SiteB_RL = SiteB_RG, SiteA_RG
Create your call route partitions
SiteACalling_PT
SiteBCalling_PT
Create your route Pattern
9.@ in SiteACalling_PT w/ whatever.RF to SiteA_RL
9.@ in SiteBCalling_PT w/ whatever.RF to SiteB_RL
Does this makes sense?
Please rate post if this helps. Thanks.
mcreilly
Are you using different partitions for the phones on the two sites? If they're both using the same partition and route list, they're going to use the first gateway listed. You probably want to have two route lists, eg RL_SiteA listing GatewayA then GatewayB, and RL_SiteB listing GatewayB then GatewayA.
sysjes
SiteA_RG = RTRA
SiteB_RG = RTRB
SiteA_RL = SiteA_RG
SiteB_RL = SiteB_RG
SiteACalling_PT
SiteBCalling_PT
