PSTN call disconnect cause 31 - Normal, unspecified
Hi Everybody,
Now i am using VG2901 version 15.2(2)T
We are using E1 curcuit to connect the PSTN
show isdn status
Layer 1 is active
Layer 2 is MULTIPLE_FRAME_ESTABLISHED
When I tried to dial the local number 28881000,  it seems cannot establish the call successfully... and drop call
Here is the debug q931 output
Mar 17 10:09:31.863: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 1234
Mar 17 10:09:31.863: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x00A0 callID = 0x8021 switch = primary-net5 interface = User
Mar 17 10:09:31.863: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x00A0
    Sending Complete
    Bearer Capability i = 0x8090A3
        Standard = CCITT
        Transfer Capability = Speech
        Transfer Mode = Circuit
        Transfer Rate = 64 kbit/s
    Channel ID i = 0xA9839F
        Exclusive, Channel 31
    Calling Party Number i = 0x0081, '1234'
        Plan:Unknown, Type:Unknown
    Called Party Number i = 0x80, '28881000'
Mar 17 10:09:31.883: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80A0
    Cause i = 0x829F - Normal, unspecified
and debug voice ccapi inout, and found out that
cc_api_call_disconnected:
   Cause Value=31
Anybody knows what is going on here?
Sam
Everyone's tags (1)
1 ACCEPTED SOLUTION
Bronze
Hi SamThe first question
Hi Sam
The first question which comes to my mind is: Does the provider allow "local dialing"?
To find out what pattern is expected by the provider I usually do this.
1.    Turn on “debug isdn q931”
2.    Call in from the number in question (In this case “28881000”)
3.    Turn off debugging
4.    Check what pattern the provider is sending
5.    Also check the “Plan” and “Type” right below the pattern
6.    Configure outgoing numbers to use the same pattern, plan and type like the provider.
Hope that helps you a little
Cheers
slashdots
1 REPLY
Bronze
Hi Sam
Cheers
slashdots
3485
