Community Member
PSTN calls drop
CallManager 4.1(3)
Calls to/from PSTN are dropping intermittently. Internal calls for same cluster is fine.
No event viewer messages on the subscriber server.
Gateways are two Cisco 3745 with 2 PRIs on one and one on the other. Nothing in the GW logs.
Gateways were upgraded with c3745-adventerprisek9-mz.124-13e.bin 5 days ago. Issue has been reported this morning.
Hall of Fame Super Gold
Re: PSTN calls drop
Hi, can you check "show controllers E1" or T1 if you have that for slips ? Chances are you need network-clock commands
Community Member
Re: PSTN calls drop
"show controller t1" returns:
T1 1/0 is up.
Applique type is Channelized T1
Cablelength is short 133
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info Firmware: 20060927, FPGA: 20, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (167 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
2672 Line Code Violations, 3059 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 2 Severely Err Secs, 1917 Unavail Secs
Re: PSTN calls drop
Hi, no slips but many errors. Monitor the router and check if at the time the calls drops, the errors increase.
Community Member
Re: PSTN calls drop
Turned out to be a DTCI equipment on the network side of pstn. Also, Cisco looked at the GW and couldn't find anything wrong.
Thank you.
196
