PSTN can't call to Auto Atenddant UCCX
Yopie Lianto
need some help here
i already configured CUCM and UCCX for Auto Attendant when i tried to call the trigger number from internal phone i can call the trigger number and hear the auto attendant.
when i call the trigger number from outside(pstn) it always failed to connect , but when i call the other extension except the trigger number it can connect.
here my config on the router
voice-port 0/0/0
supervisory disconnect dualtone mid-call
cptone ID
timeouts interdigit 2
timeouts call-disconnect 0
connection plar 3210
(3210 is the trigger number,when i tried to call 200 it success but 3210 always failed)
dial-peer voice 201 voip
destination-pattern [1-9]...
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
session target ipv4:10.7.35.3
thank you for your time
2 Accepted Solutions
Chris Deren
Sounds like CSS/PT issue. You need to ensure the Partition assigned to the cti ports and route points are listed in the CSS of the Gateway.
HTH,
Chris
Hi Yopie Lianto,
Could you please also ensure that the Route Point and the Call Control Group which are associted with the UCCX application are using the above PT. Please attach the sanpshots of the same from UCCX box.
Anand
8 Replies 8
Chris Deren
HTH,
Chris
hmm..
i already do that..
i use internal_PT(internal partition on my CTI route point) and in the gateway i use Platinum_CSS which contains all the partiton that already i create.but still failed.when i call i got one nomal tone and then busy tone for the rest
Chris Deren
You did not say what PT is assigned to cti ports. That PT needs to be in CSS of the GW.
the CTI port i create using the same PT with CTI_routepoint which is internal PT.
Hi Yopie Lianto,
Anand
the route point in CUCM and Call Control Group in UCCX use the same PT.
here some snapshot from UCCX.
Yopie Lianto
Thanks for your time..
finally i can solve the problem.
the problem:
1. all the CTI_port must be associate with jtapi and RMCM aplication user
2. command codec g711ulaw on router
thank you..
1. Not needed
2. Yes, UCCX is installed with sigle codec, so either ensure calls arriving to UCCX use the codec installed, or use transcoders.
HTH,
Chris
