Community Member
PSTN Phone disconnects after on-hold for 25 seconds
Hi all,
My PSTN phone disconnects after 25 seconds when I put it on hold from my MGCP branch router.
I don't know what other information to provide here. Please ask questions.
Thanks in advance for helping out.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: PSTN Phone disconnects after on-hold for 25 seconds
Hi Shailendra,
Please try the following command on your gateway.
no mgcp timer receive-rtcp
From this good doc;
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_command_reference_chapter09186a00801a7f2e.html#wp1370227
Hope this helps!
Rob
VIP Super Bronze
what do you mean by your pstn phone..?? Do you mean a call to the pstn or a call from the pstn..if this is it then do the following..
on your router turn on debugging..type the following in privilige mode...
debug isdn q931
term mon
place a test call and send the output of the debug
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Community Member
Hi thanks for taking the time to reply,
The call in or out to the PSTN was having the same problem.
The issue is resolved by the foll command:
as suggested by Rob.
Hi Shailendra,
From this good doc;
Hope this helps!
Rob
Community Member
Hi Rob,
Thanks. Spot on.
Did the job first time.
162
