PSTN phones is busy but CUCM does not relay the busy signal to the IP phone
bejoy.cisco
Dear Experts,
I am experiencing this issue with CUCM 9.1. When a call is made from an IP phone to a PSTN number and if the PSTN number is busy, the call goes blank. The Ip phone goes to a long silence.
What I have learned from the the debugs is that when the far end phone is busy the service provider is sending a busy signal to the voice gateway (which is an H.232 GW). But some how the GW is not able to relay it to the CUCM.
Have any one faced this issue before. Please help with your valuable solutions.
Bejoy Thomas
8 Replies 8
Ayodeji Okanlawon
Can you send us the ff:
debug isdn q931
please include calling and called number
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
I am not at the site right now. So i do not have the 'debug ISDN q931' but i do have 'Debug voice ccap inout'
calling number: 5004 (IP phone)
called number: 33512100
Voice_GW_1#
Nov  5 14:11:31.994: //-1/00B10D2AF426/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=IPT Helpdesk (TEMP)
   ----- ccCallInfo IE subfields -----
   cisco-ani=5004
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=33512100
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Nov  5 14:11:31.994: //-1/00B10D2AF426/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x3120854C, Call Info(
   Calling Number=5004,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=33512100(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=100, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=140570
Nov  5 14:11:31.994: //-1/00B10D2AF426/CCAPI/ccCheckClipClir:
   In: Calling Number=5004(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=5004(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Nov  5 14:11:31.994: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov  5 14:11:31.994: :cc_get_feature_vsa malloc success
Nov  5 14:11:31.994:  cc_get_feature_vsa count is 7
Nov  5 14:11:31.994: :FEATURE_VSA attributes are: feature_name:0,feature_time:811966896,feature_id:137618
Nov  5 14:11:31.994: //140570/00B10D2AF426/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=5004(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=33512100(TON=Unknown, NPI=Unknown))
Nov  5 14:11:31.994: //140570/00B10D2AF426/CCAPI/cc_process_call_setup_ind:
   Event=0x31581408
Nov  5 14:11:31.994: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 33512100
Nov  5 14:11:31.994: //140570/00B10D2AF426/CCAPI/ccCallSetContext:
   Context=0x2BC94C54
   >>>>CCAPI handed cid 140570 with tag 100 to app "_ManagedAppProcess_num2name"
Nov  5 14:11:31.994: //140570/00B10D2AF426/CCAPI/ccCallProceeding:
Nov  5 14:11:31.998: //140570/00B10D2AF426/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=1, Params=0x2BC7D724, Progress Indication=NULL(0)
Nov  5 14:11:31.998: //140570/00B10D2AF426/CCAPI/ccCheckClipClir:
   Destination Pattern=.T, Called Number=33512100, Digit Strip=TRUE
   Redirect Number=, Display Info=Bejoy
   Account Number=IPT Helpdesk (TEMP), Final Destination Flag=TRUE,
   Guid=00B10D2A-93FC-8127-F426-F203AC1F2383, Outgoing Dial-peer=1
Nov  5 14:11:31.998: //140570/00B10D2AF426/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=5004
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=33512100
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=74
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Nov  5 14:11:31.998: //140570/00B10D2AF426/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x315B7394, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=5004,(Calling Name=5004)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=33512100(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=1, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Nov  5 14:11:31.998: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov  5 14:11:31.998: :cc_get_feature_vsa malloc success
Nov  5 14:11:31.998:  cc_get_feature_vsa count is 8
Nov  5 14:11:31.998: :FEATURE_VSA attributes are: feature_name:0,feature_time:811968464,feature_id:137619
Nov  5 14:11:31.998: //140571/00B10D2AF426/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Nov  5 14:11:31.998: //140571/00B10D2AF426/CCAPI/ccCallSetContext:
   Context=0x2BC7D6D4
Nov  5 14:11:31.998: //140570/00B10D2AF426/CCAPI/ccSaveDialpeerTag:
Nov  5 14:11:32.126: //140571/00B10D2AF426/CCAPI/cc_api_call_proceeding:
   Interface=0x315B7394, Progress Indication=INBAND(8)
Nov  5 14:11:32.126: //140570/00B10D2AF426/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
   Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
   Call Entry(Responsed=TRUE)
Nov  5 14:11:32.126: //140571/00B10D2AF426/CCAPI/cc_api_get_called_ccm_detected:
   CallInfo(ccm detected=0)
Nov  5 14:11:32.126: //140570/00B10D2AF426/CCAPI/ccConferenceCreate:
   (confID=0x2BACB38C, callID1=0x2251A, gcid=0-0-0-0, tag=0x0)
Nov  5 14:11:32.126: //140571/00B10D2AF426/CCAPI/ccConferenceCreate:
   (confID=0x2BACB38C, callID2=0x2251B, gcid=0-0-0-0, tag=0x0)
   Conference Id=0x2BACB38C, Call Id1=140570, Call Id2=140571, Tag=0x0
Nov  5 14:11:32.126: //140570/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Nov  5 14:11:32.126: cc_api_get_xcode_stream : 4702
Nov  5 14:11:32.126: //140570/00B10D2AF426/CCAPI/cc_api_bridge_done:
   Conference Id=0xD85E, Source Interface=0x3120854C, Source Call Id=140570,
   Destination Call Id=140571, Disposition=0x0, Tag=0x0
Nov  5 14:11:32.126: //140571/00B10D2AF426/CCAPI/cc_api_bridge_done:
   Conference Id=0xD85E, Source Interface=0x315B7394, Source Call Id=140571,
   Destination Call Id=140570, Disposition=0x0, Tag=0xFFFFFFFF
Nov  5 14:11:32.126: //140570/00B10D2AF426/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0xD85E, Destination Call Id=140571)
   Call Entry(Conference Id=0xD85E, Destination Call Id=140570)
Nov  5 14:11:32.126: //140571/00B10D2AF426/CCAPI/cc_api_caps_ind:
   Destination Interface=0x3120854C, Destination Call Id=140570, Source Call Id=140571,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Nov  5 14:11:32.126: //140570/00B10D2AF426/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=140570
Nov  5 14:11:32.126: //140570/00B10D2AF426/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0xD85E, Call Id1=140570, Call Id2=140571
Nov  5 14:11:32.142: //140570/00B10D2AF426/CCAPI/cc_api_caps_ind:
   Destination Interface=0x315B7394, Destination Call Id=140571, Source Call Id=140570,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x2,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
Nov  5 14:11:32.142: //140570/00B10D2AF426/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_NONE(0x1), Vad=ON(0x2),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=6673)
Nov  5 14:11:32.146: //140571/00B10D2AF426/CCAPI/cc_api_caps_ack:
Nov  5 14:11:32.146: //140571/00B10D2AF426/CCAPI/cc_api_voice_mode_event:
   Call Id=140571
   Call Entry(Context=0x2BC7D6D4)
Nov  5 14:11:36.066: //140571/00B10D2AF426/CCAPI/cc_api_call_alert:
   Interface=0x315B7394, Progress Indication=NOT END TO END ISDN(1), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Nov  5 14:11:36.066: //140570/00B10D2AF426/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Nov  5 14:11:36.066: //140571/00B10D2AF426/CCAPI/cc_api_get_called_ccm_detected:
   Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Nov  5 14:11:36.066: //140570/00B10D2AF426/CCAPI/cc_api_get_delay_xport:
   CallInfo(delay xport=FALSE)
Nov  5 14:11:39.642: //140571/00B10D2AF426/CCAPI/cc_api_call_disconnected:
   Cause Value=17, Interface=0x315B7394, Call Id=140571
   Call Entry(Responsed=TRUE, Cause Value=17, Retry Count=0)
Nov  5 14:11:39.642: //140570/00B10D2AF426/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Nov  5 14:11:39.642: //140571/00B10D2AF426/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=140571
Nov  5 14:11:39.642: //140570/00B10D2AF426/CCAPI/ccConferenceDestroy:
   Conference Id=0xD85E, Tag=0x0
Nov  5 14:11:39.642: //140570/00B10D2AF426/CCAPI/cc_api_bridge_drop_done:
Nov  5 14:11:39.642: //140571/00B10D2AF426/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=140570, Disposition=0x0, Tag=0x0
Nov  5 14:11:39.642: //140570/00B10D2AF426/CCAPI/cc_generic_bridge_done:
Nov  5 14:11:39.642: //140571/00B10D2AF426/CCAPI/ccCallDisconnect:
   Cause Value=17, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=17)
   Cause Value=17, Call Entry(Responsed=TRUE, Cause Value=17)
Nov  5 14:11:39.642: //140571/00B10D2AF426/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Nov  5 14:11:39.774: //140571/00B10D2AF426/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x315B7394, Tag=0x0, Call Id=140571,
   Call Entry(Disconnect Cause=17, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Nov  5 14:11:39.774: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Nov  5 14:11:39.774: :cc_free_feature_vsa freeing 3065A7C8
Nov  5 14:11:39.774:  vsacount in free is 7
Nov  5 14:11:40.246: //140568/F2F421CA8564/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 1 to dstCallId 0x22519
Nov  5 14:11:40.246: //140568/F2F421CA8564/CCAPI/cc_relay_digit_begin_for_3way_conference:
   Check DTMF relay digit begin for 3way conf
Nov  5 14:11:40.338: //140568/F2F421CA8564/CCAPI/cc_api_call_digit_end:
Nov  5 14:11:40.338: //140568/F2F421CA8564/CCAPI/cc_relay_digit_end_for_3way_conference:
   Check DTMF relay digit end for 3way conf
Voice_GW_1#
Voice_GW_1#
Voice_GW_1#ter no
Nov  5 14:11:47.474: %ISDN-6-DISCONNECT: Interface Serial0/0/0:11  disconnected from 33671600 , call lasted 39 seconds
Nov  5 14:11:47.474: //140568/F2F421CA8564/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x315B7394, Call Id=140568
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Nov  5 14:11:47.478: //140568/F2F421CA8564/CCAPI/ccConferenceDestroy:
   Conference Id=0xD85D, Tag=0x0
Nov  5 14:11:47.478: //140568/F2F421CA8564/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0xD85D, Source Interface=0x315B7394, Source Call Id=140568,
   Destination Call Id=140569, Disposition=0x0, Tag=0x0
Nov  5 14:11:47.478: //140569/F2F421CA8564/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0xD85D, Source Interface=0x3120854C, Source Call Id=140569,
   Destination Call Id=140568, Disposition=0x0, Tag=0x0
Nov  5 14:11:47.478: //140568/F2F421CA8564/CCAPI/cc_generic_bridge_done:
Nov  5 14:11:47.478: //140568/F2F421CA8564/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)mon
Voice_GW_1#
Voice_GW_1#
Nov  5 14:11:47.478: //140568/F2F421CA8564/CCAPI/cc_api_get_transfer_info:
Nov  5 14:11:47.602: //140568/F2F421CA8564/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x315B7394, Tag=0x0, Call Id=140568,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Nov  5 14:11:47.602: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Nov  5 14:11:47.602: :cc_free_feature_vsa freeing 3065AB48
Nov  5 14:11:47.602:  vsacount in free is 6
Nov  5 14:11:47.602: //140569/F2F421CA8564/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Nov  5 14:11:47.602: //140569/F2F421CA8564/CCAPI/cc_api_get_transfer_info:
Nov  5 14:11:47.606: //140569/F2F421CA8564/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3120854C, Tag=0x0, Call Id=140569,
Voice_GW_1#
Voice_GW_1#
Voice_GW_1#u all
All possible debugging has been turned off
Voice_GW_1#
Voice_GW_1#
Voice_GW_1#
Voice_GW_1#
We need to know what the PSTN is sending to the gateway when the call is busy. ccapi debug wont tell us this.What we see on the voip leg is cause code 17--which is user busy. But it could be that the PSTN played a prompt or something to say that the other party has hung up...So I need the isdn q931 logs
Bejoy,
Pleaae also see this old troubleshooting link:-
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a0080111b58.shtml#voipout
You can try this on your g/way global config
voice call send-alert
voice call convert-discpi-to-prog
voice rtp send-recv
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Alex,
While I agree that the above could possibly resolve the issue, I requested the debugs so we could have a clearer picture. We resolved a similar issue a few weeks ago in the thread beelow
https://supportforums.cisco.com/message/4076621#4076621
Here is the latest 'Debug ISDN q931'
Calling number 5004 (IP phone)
called number: 33512100  (Cell Phone)
Call action: call made from IP phone to mobile phone. when the mobile phone rang I press the cancel button on the mobile phone. The call ended on the mobile phone, but the IP phone still shows 'TO 33512100' and enters a long silence. I end the call on Ip phone by pressing the 'endcall' soft key.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.11.06 16:05:32 =~=~=~=~=~=~=~=~=~=~=~=
Voice_GW_2#
Voice_GW_2#
Voice_GW_2#
*Nov  6 13:06:39.724: //-1/004F49E50100/CCAPI/cc_api_display_ie_subfields:
   cisco-ani=5004
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=33512100
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Nov  6 13:06:39.724: //-1/004F49E50100/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x22857BE8, Call Info(
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=12059
*Nov  6 13:06:39.724: //-1/004F49E50100/CCAPI/ccCheckClipClir:
*Nov  6 13:06:39.724: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Nov  6 13:06:39.724: :cc_get_feature_vsa malloc success
*Nov  6 13:06:39.728: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Nov  6 13:06:39.728:  cc_get_feature_vsa count is 1
*Nov  6 13:06:39.728: :FEATURE_VSA attributes are: feature_name:0,feature_time:1024473568,feature_id:12047
*Nov  6 13:06:39.728: //12059/004F49E50100/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
*Nov  6 13:06:39.728: //12059/004F49E50100/CCAPI/cc_process_call_setup_ind:
   Event=0x22CF86E0
*Nov  6 13:06:39.728: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
*Nov  6 13:06:39.728: //12059/004F49E50100/CCAPI/ccCallSetContext:
   Context=0x39FD8AA4
   >>>>CCAPI handed cid 12059 with tag 100 to app "_ManagedAppProcess_num2name"
*Nov  6 13:06:39.728: //12059/004F49E50100/CCAPI/ccCallProceeding:
*Nov  6 13:06:39.732: //12059/004F49E50100/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=1, Params=0x3D444844, Progress Indication=NULL(0)
*Nov  6 13:06:39.732: //12059/004F49E50100/CCAPI/ccCheckClipClir:
   Guid=004F49E5-3F3E-A127-0100-9D03AC1F2383, Outgoing Dial-peer=1
*Nov  6 13:06:39.732: //12059/004F49E50100/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=5004
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=33512100
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=74
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Nov  6 13:06:39.732: //12059/004F49E50100/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x3D06F674, Interface Type=6, Destination=, Mode=0x0,
*Nov  6 13:06:39.732: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Nov  6 13:06:39.732: :cc_get_feature_vsa malloc success
*Nov  6 13:06:39.732:  cc_get_feature_vsa count is 2
*Nov  6 13:06:39.732: :FEATURE_VSA attributes are: feature_name:0,feature_time:1024475808,feature_id:12048
*Nov  6 13:06:39.732: //12060/004F49E50100/CCAPI/ccIFCallSetupRequestPrivate:
*Nov  6 13:06:39.732: //12060/004F49E50100/CCAPI/ccCallSetContext:
   Context=0x3D4447F4
*Nov  6 13:06:39.732: //12059/004F49E50100/CCAPI/ccSaveDialpeerTag:
*Nov  6 13:06:39.732: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 5004
*Nov  6 13:06:39.736: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x174B callID = 0x96CC switch = primary-net5 interface = User
*Nov  6 13:06:39.736: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x174B
    Bearer Capability i = 0x9090A3
        Standard = CCITT
        Transfer Capability = 3.1kHz Audio
        Transfer Mode = Circuit
        Transfer Rate = 64 kbit/s
    Channel ID i = 0xA9839E
        Exclusive, Channel 30
    Calling Party Number i = 0x0081, '5004'
        Plan:Unknown, Type:Unknown
    Called Party Number i = 0x80, '33512100'
*Nov  6 13:06:39.776: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x974B
*Nov  6 13:06:39.780: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x974B
    Progress Ind i = 0x8288 - In-band info or appropriate now available
*Nov  6 13:06:39.780: //12060/004F49E50100/CCAPI/cc_api_call_proceeding:
   Interface=0x3D06F674, Progress Indication=INBAND(8)
*Nov  6 13:06:39.780: //12059/004F49E50100/CCAPI/ccCallCutProgress:
*Nov  6 13:06:39.780: //12060/004F49E50100/CCAPI/cc_api_get_called_ccm_detected:
*Nov  6 13:06:39.780: //12059/004F49E50100/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID1=0x2F1B, gcid=0-0-0-0, tag=0x0)
*Nov  6 13:06:39.780: //12060/004F49E50100/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID2=0x2F1C, gcid=0-0-0-0, tag=0x0)
   Conference Id=0xFFFFFFFF, Call Id1=12059, Call Id2=12060, Tag=0x0
*Nov  6 13:06:39.780: //12059/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Nov  6 13:06:39.780: cc_api_get_xcode_stream : 4819
*Nov  6 13:06:39.780: //12059/004F49E50100/CCAPI/cc_api_bridge_done:
   Conference Id=0x16BF, Source Interface=0x22857BE8, Source Call Id=12059,
   Destination Call Id=12060, Disposition=0x0, Tag=0x0
*Nov  6 13:06:39.784: //12060/004F49E50100/CCAPI/cc_api_bridge_done:
   Conference Id=0x16BF, Source Interface=0x3D06F674, Source Call Id=12060,
   Destination Call Id=12059, Disposition=0x0, Tag=0xFFFFFFFF
*Nov  6 13:06:39.784: //12059/004F49E50100/CCAPI/cc_generic_bridge_done:
*Nov  6 13:06:39.784: //12059/004F49E50100/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x16BF, Destination Call Id=12060)
*Nov  6 13:06:39.784: //12060/004F49E50100/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x16BF, Destination Call Id=12059)
*Nov  6 13:06:39.784: confID:0x16BF; callEntry1 callID1:0x2F1B, type:1; callEntry2 callID2:0x2F1C, type:6
*Nov  6 13:06:39.784: //12060/004F49E50100/CCAPI/cc_api_caps_ind:
   Destination Interface=0x22857BE8, Destination Call Id=12059, Source Call Id=12060,
   Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
*Nov  6 13:06:39.784: //12059/004F49E50100/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=12059
*Nov  6 13:06:39.784: //12060/004F49E50100/CCAPI/cc_api_get_called_ccm_detected:
*Nov  6 13:06:39.784: //12059/004F49E50100/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x16BF, Call Id1=12059, Call Id2=12060
*Nov  6 13:06:39.796: //12059/004F49E50100/CCAPI/cc_api_caps_ind:
   Destination Interface=0x3D06F674, Destination Call Id=12060, Source Call Id=12059,
   Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x2,
*Nov  6 13:06:39.800: //12059/004F49E50100/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_NONE(0x1), Fax Version:=0, Vad=ON(0x2),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=9154)
*Nov  6 13:06:39.800: //12060/004F49E50100/CCAPI/cc_api_caps_ack:
*Nov  6 13:06:39.800: //12060/004F49E50100/CCAPI/cc_api_voice_mode_event:
   Call Id=12060
   Call Entry(Context=0x3D4447F4)
*Nov  6 13:06:44.116: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x974B
    Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
*Nov  6 13:06:44.116: //12060/004F49E50100/CCAPI/cc_api_call_alert:
   Interface=0x3D06F674, Progress Indication=NOT END TO END ISDN(1), Signal Indication=SIGNAL RINGBACK(1)
*Nov  6 13:06:44.120: //12059/004F49E50100/CCAPI/ccCallAlert:
*Nov  6 13:06:44.120: //12060/004F49E50100/CCAPI/cc_api_get_called_ccm_detected:
*Nov  6 13:06:44.120: //12059/004F49E50100/CCAPI/cc_api_get_delay_xport:
*Nov  6 13:06:47.056: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x974B
    Cause i = 0x8091 - User busy
*Nov  6 13:06:47.056: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x174B
*Nov  6 13:06:47.056: //12060/004F49E50100/CCAPI/cc_api_call_disconnected:
   Cause Value=17, Interface=0x3D06F674, Call Id=12060
*Nov  6 13:06:47.060: //12059/004F49E50100/CCAPI/ccCallReleaseResources:
*Nov  6 13:06:47.060: //12060/004F49E50100/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=12060
*Nov  6 13:06:47.060: //12059/004F49E50100/CCAPI/ccConferenceDestroy:
   Conference Id=0x16BF, Tag=0x0
*Nov  6 13:06:47.060: confID:0x16BF; callEntry1 callID1:0x2F1B, type:1; callEntry2 callID2:0x2F1C, type:6
*Nov  6 13:06:47.060: //12059/004F49E50100/CCAPI/cc_api_bridge_drop_done:
*Nov  6 13:06:47.060: //12060/004F49E50100/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=12059, Disposition=0x0, Tag=0x0
*Nov  6 13:06:47.060: //12059/004F49E50100/CCAPI/cc_generic_bridge_done:
*Nov  6 13:06:47.060: //12060/004F49E50100/CCAPI/ccCallDisconnect:
*Nov  6 13:06:47.060: //12060/004F49E50100/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
*Nov  6 13:06:47.176: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x974B
*Nov  6 13:06:47.176: //12060/004F49E50100/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3D06F674, Tag=0x0, Call Id=12060,
*Nov  6 13:06:47.176: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Nov  6 13:06:47.180: :cc_free_feature_vsa freeing 3D104298
*Nov  6 13:06:47.180: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Nov  6 13:06:47.180:  vsacount in free is 1
Voice_GW_2#
Voice_GW_2#
Voice_GW_2#
*Nov  6 13:06:56.080: //12059/004F49E50100/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x22857BE8, Call Id=12059
*Nov  6 13:06:56.080: //12059/004F49E50100/CCAPI/ccCallDisconnect:
*Nov  6 13:06:56.080: //12059/004F49E50100/CCAPI/cc_api_get_transfer_info:
*Nov  6 13:06:56.084: //12059/004F49E50100/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x22857BE8, Tag=0x0, Call Id=12059,
*Nov  6 13:06:56.084: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Nov  6 13:06:56.084: :cc_free_feature_vsa freeing 3D1039D8
*Nov  6 13:06:56.084:  vsacount in free is 0
Voice_GW_2#
Voice_GW_2#
Hi Alex,
I tried the commands, but no luck
From the logs, it is clear why that commadn will not help because there is no PI in the disconnect.
The gateway received the proper disconect from the PSTN..
   Cause Value=17, Interface=0x3D06F674, Call Id=12060.
We can also see that the call disconnect was sent immediately..
So evrything looks okay on the gateway side. We will need to look at the CUCM logs to see whats going on and why CUCM is not telling the phone to hang up the call immediately. Can you please send us the detailed cucm traces.
