PSTN Router Config pls check
kuldeep.kaur
Hi Guys,
I am trying to setup PSTN router. Following is the configuraiton. I am not sure when I do show isdn status it says my layer 1 is shutdown. I checked the config and cant see any where they are shut. I am thinking may be because of error I am getting but not sure. Another thing is I am not sure whether I have the correct rollover cables. Even if I have wrong rollover cables the controllers should come up correct or not ? Please someone help me out. Tks
hostname PSTN
boot-start-marker
boot-end-marker
enable secret 5 $1$bJ1/$OYNeITJ2UaBepap3.PJ8u/
no aaa new-model
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-participate wic 3
dot11 syslog
ip source-route
ip cef
no ip domain lookup
ip multicast-routing
no ipv6 cef
isdn switch-type primary-net5
voice service voip
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  header-passing
  registrar server
  no call service stop
voice-card 0
username cisco password 0 cisco
redundancy
controller E1 0/0/0
clock source internal
pri-group timeslots 1-2,16
controller E1 0/1/0
pri-group timeslots 1-5,16
controller E1 0/3/0
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn send-alerting
isdn bchan-number-order ascending
no cdp enable
interface Serial0/1/0:15
description connect-sb
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn protocol-emulate network
no cdp enable
interface Serial0/3/0:15
description connect-sc
no ip address
encapsulation hdlc
isdn send-alerting
isdn sending-complete
no cdp enable
router ospf 1
network 0.0.0.0 255.255.255.255 area 0
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:gui
logging esm config
ixi transport http
response size 4
no shutdown
request outstanding 1
nls resp-timeout 1
cpd cr-id 1
control-plane
voice-port 0/1/0:15
translate called 2
voice-port 0/3/0:15
translate called 5
voice-port 0/0/0:15
mgcp profile default
gateway
timer receive-rtp 1200
sip-ua
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
password cisco
login
transport input all
scheduler allocate 20000 1000
ntp master 2
end
PSTN#show isdn st
Global ISDN Switchtype = primary-net5
ISDN Serial0/0/0:15 interface
        dsl 0, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        SHUTDOWN
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x00000000
    Number of L2 Discards = 0, L2 Session ID = 1
ISDN Serial0/1/0:15 interface
        ******* Network side configuration *******
        dsl 1, interface ISDN Switchtype = primary-ni
    Layer 1 Status:
        SHUTDOWN
    Layer 2 Status:
    Layer 3 Status:
    Active dsl 1 CCBs = 0
    Number of L2 Discards = 0, L2 Session ID = 0
ISDN Serial0/3/0:15 interface
        dsl 2, interface ISDN Switchtype = primary-net5
    Layer 1 Status:
        SHUTDOWN
    Layer 2 Status:
    Layer 3 Status:
    Active dsl 2 CCBs = 0
    Number of L2 Discards = 0, L2 Session ID = 21
    Total Allocated ISDN CCBs = 0
PSTN#show int s0/0/0:15
Serial0/0/0:15 is down, line protocol is down
  Hardware is DSX1
  MTU 1500 bytes, BW 64 Kbit/sec, DLY 20000 usec,
  Encapsulation HDLC, loopback not set
  Keepalive set (10 sec)
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 00:15:08
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/0/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 48 kilobits/sec
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions
  Timeslot(s) Used:16, SCC: 0, Transmitter delay is 0 flags
PSTN#show int s0/1/0:15
Serial0/1/0:15 is down, line protocol is down
  Hardware is DSX1
  Description: connect-sb
  Last clearing of "show interface" counters 00:15:24
PSTN#show int s0/3/0:15
Serial0/3/0:15 is down, line protocol is down
  Hardware is DSX1
  Description: connect-sc
     reliability 252/255, txload 1/255, rxload 1/255
  Last input 01:19:34, output never, output hang never
  Last clearing of "show interface" counters 00:15:41
     Conversations  0/1/256 (active/max active/max total)
PSTN#show ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0         172.16.0.1    YES NVRAM  up                    up
GigabitEthernet0/1         192.168.1.1   YES NVRAM  up                    down
Serial0/0/0:0              unassigned      YES unset  down                  down
Serial0/0/0:1              unassigned      YES unset  down                  down
Serial0/0/0:15             unassigned      YES unset  down                  down
Serial0/1/0:0              unassigned      YES unset  down                  down
Serial0/1/0:1              unassigned      YES unset  down                  down
Serial0/1/0:2              unassigned      YES unset  down                  down
Serial0/1/0:3              unassigned      YES unset  down                  down
Serial0/1/0:4              unassigned      YES unset  down                  down
Serial0/1/0:15             unassigned      YES NVRAM  down                  down
Serial0/3/0:0              unassigned      YES unset  down                  down
Serial0/3/0:1              unassigned      YES unset  down                  down
Serial0/3/0:2              unassigned      YES unset  down                  down
Serial0/3/0:3              unassigned      YES unset  down                  down
Serial0/3/0:4              unassigned      YES unset  down                  down
Serial0/3/0:15             unassigned      YES NVRAM  down                  down
PSTN#show controllers e1 0/0/0
E1 0/0/0 is down.
  Applique type is Channelized E1 - balanced
  Transmitter is sending remote alarm.
  Receiver has loss of frame.
  alarm-trigger is not set
  Version info Firmware: 20090113, FPGA: 20, spm_count = 0
  Framing is CRC4, Line Code is HDB3, Clock Source is Internal.
  Data in current interval (168 seconds elapsed):
     10531475 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 168 Unavail Secs
  Data in Interval 1:
     40709769 Line Code Violations, 0 Path Code Violations
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 900 Unavail Secs
  Total Data (last 1 15 minute intervals):
     40709769 Line Code Violations, 0 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
PSTN#show controllers e1 0/1/0
E1 0/1/0 is down.
  Framing is CRC4, Line Code is HDB3, Clock Source is Line.
  Data in current interval (182 seconds elapsed):
     9734896 Line Code Violations, 0 Path Code Violations
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 182 Unavail Secs
  Data in Interval 1:
     54478431 Line Code Violations, 0 Path Code Violations
     54478431 Line Code Violations, 0 Path Code Violations,
PSTN#show controllers e1 0/3/0
E1 0/3/0 is down.
  Far End Block Errors Detected
  Data in current interval (195 seconds elapsed):
     11638646 Line Code Violations, 0 Path Code Violations
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 195 Unavail Secs
  Data in Interval 1:
     52019089 Line Code Violations, 0 Path Code Violations
     52019089 Line Code Violations, 0 Path Code Violations,
NAME: "2821 chassis", DESCR: "2821 chassis"
PID: CISCO2821         , VID: V01 , SN: FHK0925F00U
NAME: "One port E1 voice interface daughtercard on Slot 0 SubSlot 0", DESCR: "One port E1 voice interface daughtercard"
PID: VWIC-1MFT-E1=     , VID: 1.0, SN: 32548685
NAME: "One port E1 voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "One port E1 voice interface daughtercard"
PID: VWIC-1MFT-E1=     , VID: 1.0, SN: 26682761
NAME: "One port E1 voice interface daughtercard on Slot 0 SubSlot 3", DESCR: "One port E1 voice interface daughtercard"
PID: VWIC-1MFT-E1=     , VID: 1.0, SN: 29804671
NAME: "PVDMII DSP SIMM with one DSP on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with one DSP"
PID: PVDM2-16          , VID: V01 , SN: FOC13200WJF
2 Accepted Solutions
Hi Kuldeep,
Your controller won't come UP till the E1 connections are rightly patched/connected.
you can also refer the link for Pin details of RJ-45
https://supportforums.cisco.com/docs/DOC-9474
Even after having right pins , if still controller does not come UP, try swapping pairs at either end.
regds,
aman
Yes thats right. Since you are connecting two e1 cards back to back you need to use e1 cross over cable.
Terry
Please rate helpful posts!
5 Replies 5
kuldeep.kaur
Guys the config under Int serial are wrong. Here is the correct one. Even with this it is giving me same errors pasted above
no ip address
encapsulation hdlc
isdn send-alerting
isdn outgoing display-ie
no cdp enable
no ip address
encapsulation hdlc
no cdp enable
no ip address
encapsulation hdlc
isdn send-alerting
no cdp enable
Hi Kuldeep,
First and foremost please ensure you are using E1 cross over cable. It appears you have wrong cables.
You can either make the cables if you have a crimper and some connectors or you can buy the E1 cross over cables. Refer here for E1 cross over pin lay outs: http://wiki.beronet.com/index.php/Howto_E1_/_T1_Crossover_Cable
Terry
Hi Kuldeep,
regds,
aman
Hi Guys
Really appreciated for your replies / answers. I still have one question I.e why it is
Showing layer 1 shutdown? Is it becos of wrong cables? Tks for ur help guys
Tks
Terry
