PSTN to one IP Phone
I have a cisco 2900 VoIP, organisation VoIP(internal) is all setup and working, soon we will get connected to the PSTN via E1, we will be assinged with a number which people can call, the question is: how can i add a rule for different language? press 1 for English, 2 for spanish and so on? and how can i diver all incoming calls to 5 IP phones? lets say: 7665, 7666, 7667 and so on.
Hall of Fame Super Silver
Re: PSTN to one IP Phone
You would build this on your voicemail system such as unity connection or unity express, let us know if you have it and we get guide further.
Chris
Dear Chris
Thanks for the great help, will try to figure this out, that answer goes for the call divert too? or i need to add rules?
When you say divert calls do you mean from the auto attendant menu or directly from PSTN?
Chris
let's say someone will call from outside(PSTN) with allocated number provided from Telecom Compnay, when they call, the call should only be diverted to the 5 Phone (VoIP internal) not to other phones. thanks again
What is your phone system? Is it CME, CUCM, something else?
Chris
it is a CME (cisco 2900)
by the way i am connected via Cisco Configurtion Pro, not terminal
Then simply configure the ephone-dn on the ephone that matches what you are receiving from telco, alternatively you can use things like num-exp or translation rules on the CME CLI to route the call to one extension.
HTH,
Chris
Dear Chris
Thanks mate for all the reat helps, will try your advice, and hope it will work.
NP, let us know and rate all useful posts!
Chris
93
