PSTN to PSTN CFA on an IOS Gateway ?
Hello All,
I would like to know if it is possible to forward a call on an IOS gateway that has come from PSTN back to PSTN without using the CCM.
Thanks for any advice.
Fraser
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: PSTN to PSTN CFA on an IOS Gateway ?
Translate called number with a profile. Apply it on the voice port, incoming.
Yes, you can configure a translation profile and rule to do that.
Or a minimal CME config.
can you help me out here by showing me a link to the correct PDF or giving the config to divert say
0401167422155
into
051167422157
I have a C-2950 with 15 IOS
Thanks for the FAST reply
Do you have ISDN ? Or just FXO ?
A PRI PSTN connection (30 channel)
so....something like
voice translation-rule 500
rule 1 /532011980/ /1167422159/
rule 2 /532011980/ /1167422159/
then on port
voice-port 0/0/0:15  ?
173
