PSTN users cant hear Call manager users
Im facing a quite intermitten problen when sometimes PSTN calls put on hold and tried to retrive it back PSTN users cant call manager users at all and we have the same situation when answering PSTN external  calls sometimes.Please let me know if anyone else came across this and have solution?
Is that something to do with DSPs?
Thank you
Re: PSTN users cant hear Call manager users
Your message isn't very clear (read it out loud and see if you can understand what you were attempting to say).  I think you're saying you are having a problem picking up calls that were put on hold.
You didn't describe your gateway setup (SIP, H323, MGCP, etc.), but it sounds like you're running out of MTP resources.  You should be able to see this using the RTMT tool and monitoring the MTPs.
Yea True.Thats what happens when you are not focused.
Heres the Scenario
1.When a  PSTN call put on hold and resume it you cant hear anything from PSTN users side but PSTN users can hear you well
2.When a PSTN call transfered to a another extension you cant hear anything but PSTN users can hear you
Please let me know your thought about the issue.Thank you
Are these H323 gateways to the PSTN?
NOTICE OF CONFIDENTIALITY:
The information contained in this email transmission is confidential information which may contain information that is legally privileged and prohibited from disclosure under applicable law or by contractual agreement. The information is intended solely for the use of the individual or entity named above.
If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution or taking of any action in reliance on the contents of this email transmission is strictly prohibited.
If you have received this email transmission in error, please notify us immediately by telephone to arrange for the return of the original transmission to us.
Bronze
I hope you are doing great,
I would like to confirm the following information:
Complete topology description:
Can you post a show run of the gateway?
Can you provide a complete version of call manager?
If you are having one way audio issues to the PSTN. depending on the protocol that you are using, do you already doublecheck that the gateway can pingn the IP phones?
Basically as per your notes, at the moment the first call reach the call manager, the call it is connected after that when they put the call on hold they can not retrieve the call?
Can you attach the traces of the CUCM?
Can you provide a more detailed description of the issue?
I will be waiting for this information.
Luis Sandi
Sorry guys coudnt get back to you sooner
Yes it is H323 gateway
This wasnt any issue when resuming calls or forwarding and there wasnt any config changes aswell
I reset the Trunk between call managers today and appearently issue has been resolved now.I tried restarting (not resetting) before which obviously didnt fix the issue
490
