Publisher Crashed. Need to recover the data
I have a situation here at one of our client. Publiser crashed due to hard disk failure and there is no backup and the worst thing no body remembers the CCM Admin Password. I can login with OS or Platform admin. Now we have to re build the Publiser. I have tried to reset the CCM Admin password as per the documentation but it did not worked may be because publisher is down and it cant change the password.
Now my question is can we recover the phone records like MAC Addresses, Display Names, Directory Number associated with the phones etc via CLI ? Is there any query that can display and export it to some file ? Since i cant access CCM Admin and there is no backup so it is very hard for us to note down every phone manually. Any inputs are appreciated.
Asif
1 REPLY
Re: Publisher Crashed. Need to recover the data
You should have configured regular CUCM backups with DRS to avoid this, make sure to do this once you recover the cluster
Not the easiest way to get the info but you can use any SSH program that can log the info and use run sql in CLI to start gathering data.
Searh for the DB dictionary from your CUCM version to see what you can get.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
194
