Publisher Problem
Hi All,
I encounter a problem in Cisco Call Manager. Can you help me to resolve this. Thanks in advance.
This is the alert that was shown on the screen when trying to boot up
the Cisco Publisher hard disk, both disks encounter the same issue:
Windows 2000 could not start because the following file is missing or
corrupt:
\WINNT\SYSTEM32\CONFIG\SYSTEMced startup options for Windows 2000,
press F8.
You can attempt to repair this file by starting Windows 2000
Setup using the original Setup floppy disk or CD-ROM
Select 'r' at the first screen to start repair.
Re: Publisher Problem
It is hown that something has affected your OS
So it is clear that you need to specify a down time to repair your windows system
If not succed,it'll be recommended to rebuild your ccm
Hi hythamhadad,
can you able to send any procdure to follow,
when i tried to follow what the error and the recommendation shown, by putting the standard windows 2000 cd. it shows again another error: the cd and the hardware specs have incompatible issue.
108
