VIP Super Bronze
PUBLISHER REPLICATION ISSUE!!!!!
I have a publisher replication issue on my CCM Cluster.
Running the DB Helper file did not fix the replication issue
Firstly I tried the ?Reinitialize? button on the DB Helper utility and this did not work and then later I tried the ?Republish? button on the DB Helper Utility.
Either of the functions did not work and the replication issue is still present.
Another strange thing is that, In the SQL enterprise manager, I can only see the Publisher Listed (as Local) I cant see any of my 3 subcribers in the under Micsrosoft SQL servers. Attached are the error log files that I have.
Please advise on next steps
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Re: PUBLISHER REPLICATION ISSUE!!!!!
Please try to biuld subscription manually. Here is the doc for a step by step walkthrough
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094aeb.shtml
VIP Super Bronze
I did, but it did not work. I have opened a case with TAC. Thank you.
115
