pvdm is needed?
could you help me,
Is it possible to perform calls between ip phones (sip 69xx) which is registered on the same CME 9.5 without installed PVDM.
Re: pvdm is needed?
Yes.
Please remember to rate helpful responses and identify helpful or correct answers.
pvdm is needed?
Yes
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
166
