PVDM Location
JustForVoice_2
Level 4
Level 4
I tried to configure E1s on 3845 when I tried to add the configuration under e1 I got a message that:
% Not Enough DSP services
I checked show diag I found the PVDM on slot 0 and e1 on slot 1.
I turned off the router and I moved the PVDM from slot 0 to 1 and every thing works fine.
I need to know if there is a way to use the PVDM on slot 0 to configure E1 on slot 1
Chris Deren
Yes, add the following command:
voice-card 0
  dspfarm
HTH,
Chris
DSP Sharing. If you like to read about it:
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/interop/intcnf2.html#wp1010335
Best regards,
-- Adrián.
