PVDM
Hi guys i have a cisco 2811....if i want to check which dsp is installed or wherether dsp is instaled (PVDM) which command shd i use to check it.....regards
Re: PVDM
A 'Show Diag 0' will give you information about the motherboard and which kind and quantity of PVDM(s) are installed in it.
A 'Show Voice DSP Detailed' will give you information about which DSPWare your IOS load is using.
Please help us make the communities better. Rate helpful posts!
Re: PVDM
If you want to know the actual serial number and the part number of the DSP (like PVDM2-16 etc), you should use the command "Sh inventory".
Sankar.
156
