PVDM
Unable to see voice-port command in 3845 router.
PVDM2-64 modules have been installed and displayed in "sh diag"
NM-1CE1T1-PRI has been configured and the "isdn status" is also up.
Any suggestions..
Re: PVDM
HI friend,
Did you saw this link?, may be helpful.
Notice the card type command.
http://www.cisco.com/en/US/docs/ios/12_3/feature/guide/gt_et2sw.html
- adrián.
Hall of Fame Super Gold
Re: PVDM
Hi, you cannot use NM-1CE1T1-PRI for voice, that is a data only card.
You need a VWIC or VWIC2 card for voice PRI on an ISR router.
136
