Community Member
PVDM2-32 with 3 E1
Sorry for this basic question.
I have a router 2811 that i need to install 3 - E1 cards (VWIC2-1MFT-T1/E1).
Now i need to know if i have only 1-PVDM2-32 intalled in the router , will i be able to use all 3 E1 at same time or will it give any error while allocating channels.
Actually this a lab enviornment only and not more than 1-2 calls will traverse each E1.
Appreciate your response.
1 REPLY
Super Bronze
PVDM2-32 with 3 E1
You can't allocate all 30 channels on all the E1s with just a PVDM 32.
You could set up only a few channels on each (e.g. pri-group timeslots 1-6 instead of pri-group timeslots 1-30) and that would use up only the corresponding set of DSPs (e.g. 6 out of your 32 total).
If you are using this with CUCM you would need to disable ccm-manager config or the router will download a config from CUCM with pri-group timeslots 1-30 in it, and will fail on the second E1.
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
190
