PVDM2 Question
hello
i have a voice gateway 2811 with PVDM2-32 included (on motherboard)
and NM-HDV2-1E1 without any PVDM2-XX on it and this Network Module will handle 1 E1 (30 channels) my question is that I want to let the Network Module to take DSP resourses from PVDM2-32 that is on motherboard slot, since it does not have any PVDM2, is this possible or I need to purchase a new PVDM2 for this Network Module?
and if possible how can I achieve this?
and also if this is not possible can I remove the PVDM2 on the motherboard and install it in the SIMM on the Network Module? and leave the motherboard without PVDM2?
please ur help
thanks
Hall of Fame Super Silver
Re: PVDM2 Question
You can share the DSPs by applying the "dspfarm" command under voice-card.
voice-card 0
dspfarm
HTH,
Chris
Re: PVDM2 Question
I tried dspfarm command under voice-card 0 and made a call from pstn to ip phone, it rings but calling party did not hear ring back and when call was answered there was no audio!!
please do u have any idea how to solve this?
121
