PVDM3-64 Inquiry
Hi Guys,
Does PVDM3-64 support transcoding between g722-64 to g729r8 and vice-versa.
VIP Purple
Hi , PVDM3 does not support G
Hi ,
PVDM3 does not support G.723.
You can also refer the link for list of supported codecs.
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/voice-modules-interface-cards/data_sheet_c78-553971.html
regds,
aman
Hi, Aman. Thanks for the
Hi, Aman.
Thanks for the reply. I'm referring to G722-64 not G723.
And the url you have given says g722 is supported.
Table 1. Codec Support on PVDM3 Modules
Name
Low -Complexity Codecs
Medium-Complexity Codecs
High-Complexity Codecs
PVDM3 module
G.711, ClearChannel, and Fax and Modem Passthrough
G.729a, G.729ab, G.726, G.722, and Fax Relay
G.728, G.729, G.729b, Internet Low Bitrate Codec (iLBC), and Modem Relay
VIP Purple
Hi,  that is correct .G722 is
that is correct .G722 is supported.
for sake of knowledge, I shared for G723.
regds,
aman
Hi, Aman. Thank you.
Hi, Aman.
Thank you.
VIP Purple
Hi, when u boot the ISR G2
when u boot the ISR G2 router, you get messages g723 not supported on PVDM3
regds,
aman
72
