PVDM3 Amber LED Status ?
Customer has a new 3945 router they want add that as a new voice gateway router since there was no PVDM's on it we got them new PVMD3-64, they installed the PVDM and boot the router it is recognized and they can see it if they issue commands like sh inventory and sh hardware but the PVDM status LED is "AMBER". According to Cisco doc amber means "detected but not initialized"
http://www.cisco.com/en/US/partner/docs/routers/access/2900/hardware/installation/guide/Overview.html#wp1129760
Nothing is configured since it is a brand new router will that amber light go away if we configure the voice stuff like PRI or DSP farms or do we have to configure anything to initialize that.? IOS version they are running is 15.2.3T.
Thanks for your help.
Everyone's tags (1)
Nothing needs to be initialized, i would reseat the PVDM and try again.
Please rate useful posts.
That is what I thought but just want to double check if there is anything else we need to do in the router to initialize. Thanks for your quick response.
VIP Purple
Hope the new router has come pre-loaded with Voice IOS.If the Voice IOS order was placed not with 3945 router, then, u need to upload voice IOS and also licenses , which need to be enabled by commands.
Can u share the show version /show diag and show inventory for 3945 router?
regds,
aman
Re: PVDM3 Amber LED Status ?
I will get all that information on Monday. Thanks for your help.
VIP Purple
Also, try to get show license all and show license feature from the router.
regds,
aman
We fixed it after verifying license it came with only security package enabled, UC package was not eanbled as soon as we enabled it, that fixed the issue.
VIP Purple
Thanks for update.
regds,
aman
685
