Community Member
Q IPCCX
hi
i have a simple question on IPCCX scripting:
i want to build a script that will route a list of calling numbers (VIP List) to specific agents while all other callers to a CSQ.
my question is that how and where to assign the ANI list of those VIP callers in a script
i tried to add a variable called ANI with a condition of ANI.startsWith
but i want some kind of ANI equals list of VIP ANI numbers?
please help?
Re: Q IPCCX
You should be able to write a script that matches the Call Contact Info to an varible. From there, you should be able to if then statement matching on the numbers. You might need to write a If then statement for everyone ANI match. I think it should look something like so:
Get Call Contact and write it to variable X.
If Variable X == "X" then X.
Community Member
Re: Q IPCCX
Hello everyone,
I need the help for the following situation:
I need to create a filter so that only 2 agents(resources) receive calls from a number location.
I have 25 agents(Resources) and i need to only 2 agents(Resources) receive calls from this particular location.
So i created this steps in my IPCC Express.
First:
1- Create another Skill ( New_Skill )
2- Create another CSQ ( New_Queue )
3- Assign the New_Skill to all 2 Agents .
4- Make the CSQ is Skill routing based and add the New_Skill into the New_Queue .
I create a script for check the calling number and send to a CSQ_Queue:
Second:
Label:CSQ_New
Select Resource(--Triggering Contact--, CSQ_New)
ANI = (Get Call Contact Info (--Triggering Contact--, Calling Number)
If ANI == 085 then
True
Goto CSQ_New
False
Goto Queue
Will this script work?
Thank you!
Bruno.
Community Member
Re: Q IPCCX
Any sugestions about this??
Community Member
Re: Q IPCCX
Can anyone help??
Re: Q IPCCX
Hi Bruno,
Yes that script logic should work ok.
You might have received more replies if you posted in the Contact Center forum
Community Member
Re: Q IPCCX
Thank you so much James!!
I'm new in this forum, and i will posted in Contact Center now!!
Thanks again!!
173
