Q on cme
user-cisco
hi
i want to use my 2811 gateway as cme, i downloaded 12.4.11XJ ip voice image that supports 4.1 cme, according to cme admin guide i have to install cme-basic-xxx.tar file for cme to work, the issue is that i can't find this tar file in cco, i can only find cme-gui-xxx.tar files and a zip cme 4.1 file for 12.4.11XJ, but even this it does not have cme-basic-xxx.tar file, can any one help me in this issue?
it is not restricted with 12.4.11XJ, there are other ios images that support cme but does not have cme-basic-xx.tar file. do i miss a thing here?
please help
7 Replies 7
gogasca
Level 10
Level 10
Try to enter the telephony-service command.
that file afaik contains loads and some config files for phones.
If you download the file cme-124-11XJ.zip with your cco aacount, you will have all the the files needed for your ios version.
This is the link to the download : http://www.cisco.com/cgi-bin/Software/Tablebuild/doftp.pl?ftpfile=cisco/voice/ip-phone/ip-key/cme-124-11XJ.zip&app=Tablebuild&status=showC2A
This file will have the phone loads, cme gui, ringtones etc that you need to upload to the routers flash.
Rgds,
Jeroen
thanks jeroenhermans for ur response
actually i downlaoded it it is a zip file, but i wonder it does not contain the cme-basic-xxx.tar file?
second, should i just copy all files inside this zip to router flash?
another thing please, i downloaded (c2800nm-ipvoicek9-mz.124-15.T.bin) ios, and according to compatibilty matrix, this ios needs (cme-basic-4.1.0.0.tar) tar file, i downloaded it and extracted it into the flash, but the show flash output is ((invlaid checksum)) besides each copied file like this:
flash/term06.default.loads [invalid checksum]
flash/Readme7960-40.txt [invalid checksum]
please help?
thanks
the cme-basic-xxx.tar file is the same as you downloaded but with a few less files.
What you downloaded has everything you need.
According to the cme compatibility matrix (http://www.cisco.com/en/US/products/sw/voicesw/ps4625/prod_installation_guide09186a00805acf50.html) indeed your version of IOS needs CME 4.1
The easiest to get your gui files, ringtones etc on your router's flash is to run a small tftp server. You can download one from this site : http://tftpd32.jounin.net/
untar the cme-gui-4.1.0.1.tar to the same dir as the tftp server and start the tftp server
from your router do copy tftp flash:
follow the instructions to enter tftp server address filename etc
When this is done, upload the phoneloads you need. for instance, for the 7940/7960, upload P00308000500.bin,P00308000500.loads,P00308000500.sb2,P00308000500.sbn to the flash.
Go to configuration mode and enter telephony-service
type web admin system name admin password yourpassword
exit telephony-service and enable your http server by doing this :
ip http server
ip http authentication local
ip http path flash:
after doing this, you should be able to connect to the cme webinterface by browsing to http://routerip/cme.html
Rgds,
jeroen
thanks jeroen
is there any way to add these files at once? or i'm limited just to add them manually?
You can add them all at once. I believe there is a command where you can tar -zxf directly from the tftp location. Don't know the exact command anymore.
Rgds,
Jeroen
The command to add them all at once is
archive tar /xtract tftp://192.168.1.1/cme-basic-4.0.0.0.tar flash:
