Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Q on cme
hi
i want to use my 2811 gateway as cme, i downloaded 12.4.11XJ ip voice image that supports 4.1 cme, according to cme admin guide i have to install cme-basic-xxx.tar file for cme to work, the issue is that i can't find this tar file in cco, i can only find cme-gui-xxx.tar files and a zip cme 4.1 file for 12.4.11XJ, but even this it does not have cme-basic-xxx.tar file, can any one help me in this issue?
it is not restricted with 12.4.11XJ, there are other ios images that support cme but does not have cme-basic-xx.tar file. do i miss a thing here?
please help
Green
Re: Q on cme
Try to enter the telephony-service command.
that file afaik contains loads and some config files for phones.
Re: Q on cme
If you download the file cme-124-11XJ.zip with your cco aacount, you will have all the the files needed for your ios version.
This is the link to the download : http://www.cisco.com/cgi-bin/Software/Tablebuild/doftp.pl?ftpfile=cisco/voice/ip-phone/ip-key/cme-124-11XJ.zip&app=Tablebuild&status=showC2A
This file will have the phone loads, cme gui, ringtones etc that you need to upload to the routers flash.
Rgds,
Jeroen
Re: Q on cme
thanks jeroenhermans for ur response
actually i downlaoded it it is a zip file, but i wonder it does not contain the cme-basic-xxx.tar file?
second, should i just copy all files inside this zip to router flash?
another thing please, i downloaded (c2800nm-ipvoicek9-mz.124-15.T.bin) ios, and according to compatibilty matrix, this ios needs (cme-basic-4.1.0.0.tar) tar file, i downloaded it and extracted it into the flash, but the show flash output is ((invlaid checksum)) besides each copied file like this:
flash/term06.default.loads [invalid checksum]
flash/Readme7960-40.txt [invalid checksum]
please help?
thanks
Re: Q on cme
the cme-basic-xxx.tar file is the same as you downloaded but with a few less files.
What you downloaded has everything you need.
According to the cme compatibility matrix (http://www.cisco.com/en/US/products/sw/voicesw/ps4625/prod_installation_guide09186a00805acf50.html) indeed your version of IOS needs CME 4.1
The easiest to get your gui files, ringtones etc on your router's flash is to run a small tftp server. You can download one from this site : http://tftpd32.jounin.net/
untar the cme-gui-4.1.0.1.tar to the same dir as the tftp server and start the tftp server
from your router do copy tftp flash:
follow the instructions to enter tftp server address filename etc
When this is done, upload the phoneloads you need. for instance, for the 7940/7960, upload P00308000500.bin,P00308000500.loads,P00308000500.sb2,P00308000500.sbn to the flash.
Go to configuration mode and enter telephony-service
type web admin system name admin password yourpassword
exit telephony-service and enable your http server by doing this :
ip http server
ip http authentication local
ip http path flash:
after doing this, you should be able to connect to the cme webinterface by browsing to http://routerip/cme.html
Rgds,
jeroen
Re: Q on cme
thanks jeroen
is there any way to add these files at once? or i'm limited just to add them manually?
Re: Q on cme
You can add them all at once. I believe there is a command where you can tar -zxf directly from the tftp location. Don't know the exact command anymore.
Rgds,
Jeroen
Re: Q on cme
The command to add them all at once is
archive tar /xtract tftp://192.168.1.1/cme-basic-4.0.0.0.tar flash:
492
