[q] two stage LD dialing over ISDN PRI ?
Is it possible to implement following scheme of Long distance calls on CCME with PSTN over E1 ISDN PRI ?
Long distance call have to be dialed as:
<local_number_of_telephone_provider_7D><pause><pin_code><pause> <long_distance_number>
If PSTN is FXO line I can use  pause “,” in prefix but over IDSN PRI it is not possible?
Any ideas ?
1 REPLY
Re: [q] two stage LD dialing over ISDN PRI ?
In case of ISDN you will dial the PIN only once the ISDN Connect is recceived on the D Channels since only then does the two way cut through happens. The CME system would not offer such automated control to dial digits once the Call is connected.
You can achieve this by a TCL script on flash, though you will need to get one developed or try your hands at one yourself.
Check -
http://www.cisco.com/en/US/docs/ios/voice/ivr/configuration/guide/ivrapp01.html
Udit
180
