Q - Unity
hi
may be a silly question....
on cisco unity i want to define two greetings one for inside working hours and the other for outside working hours, i did the following:
opening greeting 1 call handler assigned to inside working hours schedule, and opening greeting 2 call handler assigned to outside working hours schedule
then, i pasted the appropriate recording wav files for both call handlers
also under Call Routing i added inside working hrs item and outside working hrs item.
but what happened is this:
the opening greeting works for inside working hours
but for outside working hours it says: welcome to cisco unity messaging system from a touch tone telephone you may dial.......
please can you help, why the outside working hours greeting is not played?
thanks
1 ACCEPTED SOLUTION
Re: Q - Unity
When you are in the "Greetings" Section, there are 4 greeting options you can configure
1. Standard 2. Closed 3. Internal 4. Alternative.
Right now you only have "Standard" recording on.
You have to record your "Closed" recording
Re: Q - Unity
you need to configure the closed greeting so it is played during the closed hours.
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Re: Q - Unity
thanks javalenc for fast response i created two opening greetings one for opening hours and one for closed hours, but it the for closed hours it didn't work it says: (welcome to cisco unity messaging system from a touch tone telephone you may dial any extension .....etc)
i think i missed something but i don't know what is that thing?
Re: Q - Unity
113
