Community Member
QCT 3.0.0 Fails to discover router via Serial Interface
I am having problems with QCT 3.0.1 - it never returns from auto discovering the router I am trying to configure. I get a browser window that is titled "-- Web Page Dialog" with noting in it. At the bottom, it shows the java script command that it is trying to execute. It is "javascript.document.writeln("<script>window.setTimeout(funt" - that's all that is visible as the window is not resizeable. Nothing ever returns and I have to close about 10-20 of these windows before the utility returns to the QCT interface and fails.
Anyone else seen this and figured out how to work around?
1 REPLY
Community Member
Re: QCT 3.0.0 Fails to discover router via Serial Interface
Any luck figuring this issue out? I'm running into the same problem..
Thanks..
166
