QFINITY recording system
Hernan Moya
Hi All,
We have implemented QFINITY voice recording. There are 2 remote offices through a VLAN and this VLAN is being monitored on a port of a 3560. In this port, the QFINITY server is connected. The problem is that phones of these remote offices are hearing a beep during the conversation, at random.
Has anyone had any similar problem or can guide us to detect the problem?
thanks
Hernan
anchoudh
Level 9
Level 9
Hi Hernan,
Can you please check this Phone parameter that is invoked even if you aren't using any Recording Software;
From   Cisco Unified Communications Manager Administration, choose Device  >  Phone > Phone Configuration > Product Specific Configuration
Recording Tone:
Indicates  whether a recording tone (often referred to as a beep tone) is enabled  or disabled for the phone. If the recording tone option is enabled, the  phone plays the beep tone in both directions of every call, regardless  of whether the call actually gets recorded. The beep tone first sounds  when a call is answered.
You may want to notify your users if you enable this option.
Reference:
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7962g_7942g/7_0/english/administration/guide/62adg70.pdf
Hope it helps.
Anand
Please rate helpful posts by clicking on the stars below the right answers !!
Hi Anand,
Thanks for your reply but this parameter is not present in Phone Specific Configuration. Call Manager version is System version: 8.0.3.20000-2
I check the Call Manager Service in Service Parameters and I see this parameters
Do you have another idea?
Hernan
Robert Thomas
Level 7
Level 7
If this a Active or Pasive Solution? If they integrate via CTI the remote application has control over playing the tone or not when the recording session goes active.
It is a passive solution. There are two remote offices that are in separate voice vlan and this voice vlan is monitoring to the switch port where the Qfiniti recorder is connected.
Hernan
