QIG DECODE COMMEND
iptuser55
Level 6
Level 6
I`m testing names across a H323 link and have previously configured QSIG DECODE on a IOS 12.4 Router however when I tried to enter on the router below I have no option after enter VOICE SERVICE VOIP
Cisco IOS Software, 3800 Software (C3845-IPVOICEK9-M), Version 12.4(13e), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 13-Dec-07 20:10 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
xxxxx uptime is 20 weeks, 4 days, 20 hours, 32 minutes
System returned to ROM by reload at 12:09:47 UTC Sun Jan 31 2010
System image file is "flash:c3845-ipvoicek9-mz.124-13e.bin"
At a Ciso url http://www.cisco.com/en/US/docs/ios/12_3t/voice/command/reference/vrht_q1.pdf     it shows that it was introduced at
This command was integrated into Cisco IOS Release 12.4(9)T.
Any ideas -thanks
paolo bevilacqua
As the document says, update IOS.
Am I not already above t
he suggested IOS 124-13e.bin?
No you are not. Use T not mainline.
