QoS - Clarification
L2 switchport is trust the device. Then, will L2 switch use the dscp value to classify the traffic or the cos value ?
Super Bronze
Re: QoS - Clarification
You set the switchports (depending on hardware and software versions) like so:
mls qos trust dscp (to use DSCP to classify)
mls qos trust cos (to trust CoS)
If you have the port set up to conditionally trust the cisco-phone, then it uses CoS and can optionally instruct the phone to mark down PC-port traffic.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
L2 switchports won't look at DSCP values since DSCP is a L3 header. CoS tags are only carried through on trunk links. L3 switchports won't trust DSCP, and you need to trust it with the 'mls qos trust' commands recommended above.
100
