Community Member
QoS config on 6509
Hi, All
I have a 6509 at the core of my network.  I'm preparing the LAN for a coming VoIP deployment.  It was pretty simple for the edge closets as they all have versions of IOS that support the auto qos macros.  My 6509, however, does not support the auto qos commands.  Does anyone know if I can simply copy the statements that the auto qos commands added to the edge switch (3560s) config into my 6509's config?
Thanks!
Re: QoS config on 6509
Are you running CatOS or Native mode on your switch?  Are the ports that voice is flowing through on this switch configured as L2 or L3 ports?
Community Member
The 6509 is running IOS and carries voice on L2 & L3 interfaces.
Also post "show version" and "show module" on the 6500.
Francisco
188
