QoS configuration for voip on 2960 with lan lite image
Hello all,
Does anyone have a example of a QoS configuration for Catalyst 2960 with lan lite image?
Bahlul
HiKindly find the below links
Kindly find the below links:-
http://voiceinitiate.com/2013/08/18/enterprise-qos-design-and-configuration-samples-for-2960-lan-lite-3750-and-6509e-catalyst-switches-part-one/
Please rate all useful information
Hello Islam,These commands is
Hello Islam,
These commands is not working on 2960 with lan lite ios image
Bahlul
Hi is "mls qos" command
is "mls qos" command support ?. Please confirm
plese rate all useful information
Hi,It supports "mls qos", but
It supports "mls qos", but it doesn't support "auto qos voip cisco-phone" interface subcommand.
Bahlul
Hi Just try under interface
Just try under interface the below after you enable on general config mls qos
interface x/x/x
mls qos trust cos
mls qos trust device cisco-phone
thanks
please rate all useful information
Hi,I did it before, but there
I did it before, but there is no result.
Bahlul
There is no auto qos support
There is no auto qos support on Lan Lite. You might have to copy paste the auto qos config from the 2960 QoS administration guides.
Please rate useful posts.
Hello George,Thx a lot for
Hello George,
Thx a lot for your response.
459
