Community Member
qos for Ip Phone
Hi, all..Please How do I implement qos for my Ip phones.. Can any one help with some configuration examples...Thanks
Hall of Fame Super Silver
Re: qos for Ip Phone
QoS confiuration needs be customized for given environment as there are different toolsets used based on your topology.
I'd recommand reading the QoS SRND at cisco.com/go/srnd to get an idea of what's available. Alos, if you only have LAN environemnt the AutoQoS feature is sufficient.
HTH, please rate all posts!
Chris
Community Member
Thanks, I have only a LAN environment. However, the auto qos command is not available on my platform..3825 ios 12.4(9T) ..what do u think I can do
So do you have an etherswitch module inside the router? Where do your phones connect to? If not to the etherswitch on the router then you should not even touch it for QoS if there is no WAN.
Chris
Community Member
My Ip phone connect to my catlayst 3750 switch..I do not have a WAN environment..
Then follow the SRND doc for AutoQos configuration on 3750 switch.
Chris
303
