QoS for UCM on Supervisor 2T
I have a basic QoS setup on my 6500 with a Supervisor 2T
I am using auto qos voip cisco-phone on the ports with phones attached
But what do I do for the ports where my call manager (UCM) is attached
I have templates and guides for the older architectures (Sup32, 720, etc.), but I have no idea what to do on the Supervisor 2T
Does anyone have an example of a basic QoS setup for those ports?
2 ACCEPTED SOLUTIONS
Silver
Just do auto qos voip trust on those ports.
That means trust DSCP enable by default under ports . This is ok nowadays , as all environement has many traffic for voice , data and video. Any way , i think you have to find the below table . If you need go to post your question also with infrastructure - LAN routing and switching on CSC , i think people their many have experience for your issue.
Table 8. Summary of Command Migration for Cat6500 Specific Global CLI
PFC3 Command
Sta-tus
PFC4 Migration NVGEN and Action
Comments on PFC4 Behavior
mls qos
P
auto qos default
Used in mls qos trustmigration actions as indicator of existing PFC3 configuration
Auto-configure default queueing on ports without queueing policy. No direct effect on Earl policing/marking.
Migration actions triggered if mls qosis seen on bootup or on configuration copy.
no mls qos
I
Ignored
No effect in PFC4 platform
mls qos queueing-only
R
platform qos queueing-only
Queueing behavior identical to auto qos default. Policing/marking and DSCP/CoS rewrite is disabled.
no mls qos rewrite ip dscp
P
no platform qos rewrite ip dscp
Same behavior as in PFC3. Not necessary: PFC4 rewrite control is per-class
mls qos marking ignore port-trust
I
Used as indicator that PFC3 port trust commands can be ignored
Port trust ignored in PFC4 marking, by default
mls qos marking statistics
R
platform qos marking statistics
mls qos police serial
I
Ignored
Serial mode is always on in PFC4
mls qos police redirected
I
Ignored
Ingress policing of redirected packets is always enabled
Egress policing of packets to RP is always disabled, except for CPP
Egress policing of packets, redirected to service cards, is controlled by a policy on the respective egress VLAN
mls qos map
R
table-map
Same behavior as in PFC3. Certain dscp map names are auto-converted to discard-class map names
mls qos aggregate-policer
R
platform qos aggregate-policer
mls qos protocol
R
platform qos protocol
mls qos statistics-export
R
platform qos statistics-export
mac packet-classify use vlan
I
N/A
VLAN field is always enabled in PFC4 MAC ACLs
mls qos gre input uniform-mode (ST2)
I
N/A
Uniform mode is default and is controlled by C3PL per ingress policy class
mls mpls input uniform-mode (ST2)
I
N/A
Table 9. Summary of Command Migration for Cat6k Specific Interface CLI
PFC3 Command
Sta-tus
mls qos trust cos
R
platform qos trust cos
Initial ingress discard-class mapped from COS. Does not rewrite packet DSCP.
PFC4 Differences:
In port-based mode, port trust cos is ignored if there is a port (ingress) policy
In VLAN-based mode, port trust cos is ignored in both default and VLAN policy case
mls qos trust dscp
I
N/A
Default behavior in PFC4 and C3PL
mls qos trust precedence
I
N/A
Handling is the same as mls qos trust dscp. Low 3 bits of incoming DSCP are not zeroed
no mls qos trust
R
platform qos trust none remark
Converted to trust none if mls qos present, otherwise, ignored. Ignored in VLAN-based mode
mls qos trust extend
R
platform qos trust extend
mls qos trust device
R
platform qos trust device
mls qos mpls trust experimental
R
platform qos mpls trust experimental
mls qos vlan-based
R
platform qos vlan-based
mls qos dscp-mutation
R
platform qos dscp-mutation
mls qos exp-mutation
R
platform qos exp-mutation
R
mls qos bridged
I
N/A
Auto-enabled/disabled internally per NetFlow profile, depending on the presence of microflow policing
mac packet-classify
R
mac packet-classify input
Equivalent to mac packet-classify input
mls qos loopback
R
platform qos loopback
mls qos queueing mode
R
platform qos queueing mode
Same behavior as in PFC3. Not supported in C3 LCs
mls qos cos
R
platform qos cos
wrr-queue
R
wrr-queue
rcv-queue
R
rcv-queue
pri-queue
R
pri-queue
mls qos channel-consistency
R
platform qos channel consistency
Enabled by auto qos default. Future: member ports must have the same ingress and egress queueing policy.
Table 10. Summary of Migration for Cat6K Specific Policy Map Commands
PFC3 Command
Sta-tus
Comments on PFC4 behavior
trust dscp
R
trust dscp
trust precedence
R
trust precedence
Handling is the same as trust dscp. Low 3 bits of incoming DSCP are not zeroed
trust cos
R
trust cos
PFC4 Differences:
The incoming 802.1q CoS is always used unless port CoS override configured. Warning to user to use set dscp cos or set-dscp-cos-transmit in police conform-action.
no trust
I
N/A
Packet QoS is preserved by default
police {exceed| violate} policed-dscp
R
police... {exceed| violate} policed-dscp
Retained as part of C3PL syntax
police flow
R
police flow
police aggregate
R
police aggregate
Thank you
please rate all useful information
Silver
Ah ok lol
If the UCM server is on a port-channel, do I do auto qos voip trust on the channel interface or do I have to do it on each individual interface/
The QOS should be enabled under the physical port not port channel. You have to to enable it to your physical ports.
Thank you
Apparently,
auto qos voip trust
is not supported on port-channels
Someone said something about taking the config that would normally be applied and doing it manually
would that be
priority-queue queue-limit 5
wrr-queue queue-limit 65 15 15
wrr-queue random-detect min-threshold 1 70 100 100 100 100 100 100 100
wrr-queue random-detect min-threshold 2 70 100 100 100 100 100 100 100
wrr-queue random-detect min-threshold 3 40 40 50 50 60 60 70 70
wrr-queue random-detect max-threshold 1 100 100 100 100 100 100 100 100
wrr-queue random-detect max-threshold 2 100 100 100 100 100 100 100 100
wrr-queue random-detect max-threshold 3 70 70 80 80 90 90 100 100
wrr-queue cos-map 2 1 1 2
wrr-queue cos-map 3 5 3 4
wrr-queue cos-map 3 7 6 7
As i mentioned above the auto qos voip trust , should be applied under physical ports not inder port channel.
Thank you
1- priority-queue, mls qos trust  and auto qos voip trust commands apply under physical ports , for Port channel just configuration for (switchport mode tunk , etc).
Thank you
I won't accept the auto qos voip option on any of the physical ports if those ports are members of a port-channel
HI
i am sure that the  above will meet you case your case  , but if your have a scinario as QOS and mls dscp & mls cos. In this case under the portchannel you can apply mls qos trust dscp trust . If i have a traffic for example MGCP and you do a QOS with access lists, class maps , pilcy map then you have to apply. In this case you can use your port channel to trust th incoming traffic. This QOS portchannel only supportd for (ASR , GSR, 6500,N7K,etc).
Thank you
my answer about the command which you mentioned above. Please tell me the port chanel will be as L3 , trunk or what ?.After that i can help you to do a configuration which will be ok.
Thank you
The trunk uses LACP for port-aggregation and the port-channel interface has an IP assigned.
6 interfaces are in the group
config:
interface Port-channel71
switchport
switchport trunk allowed vlan 97,98
switchport mode trunk
switchport nonegotiate
I have auto qos assigned to phone ports and voice router ports: the environment is pretty basic--it is a remote office that serves as a call center, so there are no competing video streams, heavy DB traffic etc.
for your case under portchannel , please try the below and dont do any thing on the pysical members
mls qos
mls qos map cos-dscp 0 8 16 24 34 46 48 56
Switch(config-if)#wrr-queue bandwidth 30 70
Switch(config-if)#wrr-queue threshold 1 40 100
Switch(config-if)#wrr-queue threshold 2 80 100
Switch(config-if)#wrr-queue cos-map 1 1 1
Switch(config-if)#wrr-queue cos-map 1 2 0
Switch(config-if)#wrr-queue cos-map 2 1 2 3 4 6 7
Switch(config-if)#wrr-queue cos-map 2 2 5
Switch(config-if)#mls qos trust dscp
Thank yo
Will that configuration work for the
WS-X6148E-GE-45AT
line cards?
(thanks for your help by the way!)
As a sample configuration it should work so fine , did you test ?. Please test and share with me.Please find also the below link
http://www.dslreports.com/faq/13324
Thank you
won't let me do this on the port-channel interface (po70 or po71)
no wrr-queue or mls options
It does accept the wrr-queue options under the physical interface, but will not take any mls related commands (so I am not sure how to specify trust).
I think this is because of the new Supervisor 2T -everything appears to be different
This may be , i am sure that is ok on sup  720 . I am sure that mls qos trust dscp is ok under port channel . Look you can use auto qos voip trust under physical ports and just type under port channel  mls qos trust dscp .
Thank you
I was looking at the Cisco migration document
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/15.1SY/config_guide/sup2T/qos_migration.html
It says for the command
mls qos trust dscp
"No SY equivalent; corresponds to the SY default nonconfigurable condition."
I assume this means that  the new command
auto qos default
marks ports as trusted by default? It is unclear.
Well I tried to copy the QoS settings to the physical ports in the channel and it immediately put all my ports into a suspended mode, and I cannot back out the QoS
so now I had to reboot the entire VSS -not good
It looks like QoS is not fully supported (or might not be supported at all) in a Supervisor 2T setup with port-channels.
Big problem for us, considering we want to channelize our UCM servers
PFC3 Command
Sta-tus
mls qos
P
auto qos default
no mls qos
I
Ignored
R
P
I
R
I
Ignored
I
Ignored
mls qos map
R
table-map
R
mls qos protocol
R
R
I
N/A
I
N/A
I
N/A
PFC3 Command
Sta-tus
mls qos trust cos
R
PFC4 Differences:
mls qos trust dscp
I
N/A
I
N/A
no mls qos trust
R
R
R
R
mls qos vlan-based
R
R
R
R
mls qos bridged
I
N/A
mac packet-classify
R
mls qos loopback
R
R
mls qos cos
R
platform qos cos
wrr-queue
R
wrr-queue
rcv-queue
R
rcv-queue
pri-queue
R
pri-queue
R
PFC3 Command
Sta-tus
trust dscp
R
trust dscp
trust precedence
R
trust precedence
trust cos
R
trust cos
PFC4 Differences:
no trust
I
N/A
R
police flow
R
police flow
police aggregate
R
police aggregate
Thank you
311
