QoS for voice on a multi-link frame relay interface / subinterfaces
My question is in regards to QoS on an MFR interface/subinterfaces. We have a remote site with two bundled T1's terminating on a 2951 router for a total bandwidth of 3072. The circuit is provided by Paetec and the subinterfaces are designated for internet and MPLS traffic respectively. The issue we are facing is with outbound voice quality. It seems that no matter how we apply QoS, either to the main MFR interface or the MFR subinterfaces, voice packets do not seem to be prioritized. We tried FRTS, which slowed the entire link down to a crawl, we tried applying a class map to the main interface as well as a service policy, none of which seemed to affect anything. Please see below for current partial configuration. Any input will be greatly appreciated.
class-map match-all VOICE
match ip dscp ef
class-map match-any SIGNALING
match ip dscp af31
match ip dscp cs3
class-map match-all AZ-SERVERS
match access-group 10
policy-map VOICE-POLICY
class VOICE
    priority 640
class SIGNALING
    bandwidth 64
  set dscp af41
class AZ-SERVERS
    police 1000000
class class-default
    fair-queue
interface Loopback1
no ip address
interface Tunnel1
no ip address
interface MFR1
no ip address
ip flow ingress
ip flow egress
load-interval 30
frame-relay lmi-type ansi
service-policy output VOICE-POLICY
interface MFR1.501 point-to-point
description => Internet via PAETEC
ip vrf forwarding internet
ip address 63.255.X.X 255.255.255.252
ip flow ingress
ip flow egress
no cdp enable
frame-relay interface-dlci 501 IETF
interface MFR1.502 point-to-point
description => MPLS VPN via PAETEC
ip address 63.253.X.X 255.255.255.252
ip flow ingress
ip flow egress
no cdp enable
frame-relay interface-dlci 502 IETF
Green
Can you post the output of
show policy-map interface mfr1 out
Alex
Regards, Alex. Please rate useful posts.
Sure. I've looked at this output in the past and do see voice packets being treated with priority as well as policing on data from some servers but we continue to have voice issues.
AZ-2951VG1#sh policy-map int
MFR1
  Service-policy output: VOICE-POLICY
    queue stats for all priority classes:
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 6867970/1396926660
    Class-map: VOICE (match-all)
      6867971 packets, 1395297936 bytes
      30 second offered rate 0 bps, drop rate 0 bps
      Match: ip dscp ef (46)
      Priority: 640 kbps, burst bytes 16000, b/w exceed drops: 0
    Class-map: SIGNALING (match-any)
      179239 packets, 10913653 bytes
      Match: ip dscp af31 (26)
        11784 packets, 2323721 bytes
        30 second rate 0 bps
      Match: ip dscp cs3 (24)
        167455 packets, 8589932 bytes
      Queueing
      (pkts output/bytes output) 179239/10960789
      bandwidth 64 kbps
      QoS Set
        dscp af41
          Packets marked 179239
    Class-map: AZ-SERVERS (match-all)
      2547381 packets, 2400552064 bytes
      30 second offered rate 23000 bps, drop rate 0 bps
      Match: access-group 10
      police:
          cir 1000000 bps, bc 31250 bytes
        conformed 2504654 packets, 2338453602 bytes; actions:
          transmit
        exceeded 42727 packets, 62098462 bytes; actions:
          drop
        conformed 23000 bps, exceed 0 bps
    Class-map: class-default (match-any)
      3807965 packets, 973152148 bytes
      30 second offered rate 13000 bps, drop rate 0 bps
      Match: any
      Queueing
      (queue depth/total drops/no-buffer drops/flowdrops) 0/380109/0/380109
      (pkts output/bytes output) 5978340/3298256266
      Fair-queue: per-flow queue limit 16
Green
So you are or at least have been matching VOIP EF traffic
One thing you could try is looking at the T1 tx ring size
For voice traffic you may need to cut this down.
A similar config I have showed that the TX ring had been put down to 2
no tx-queue-limit
tx-ring-limit 2
Verify what you have before making any changes
Know how to revert
Alex
Verified the tx limit is set to 2.
Green
So its looks to me like you are prioritizing the EF traffic OK.
Is the WAN carrier SP providing QOS end to end for you too.
Your config looks good to me.
Alex
They are, that was one of the first places we turned to in order to troubleshoot. Strange.
301
