Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
QoS for Voice traffic
I am trying to understand why a particular policy was put in place and what is it doing.
We have this at all of our remot ebranches which is using VoIP fo inter office calls:
policy-map PEFCU-QoS
class VOICE
priority 256
set dscp ef
class DATA-Priority
bandwidth 128
set dscp af31
class class-default
set dscp default
fair-queue
random-detect
Each site has a full T1.
Am I to understand that anything mathing the access-list in class VOICE will get 256K of the pipe and will be prioritized over any other traffic?
And why the "priority" designation?
Does this give that traffic prioirty over any other class?
Also, the DATA gets 128K of the pipe and is prioritized only if there is not VOICE traffic?
And all othere traffic gets the rest of this pipe?
Re: QoS for Voice traffic
The "priority" command speciifies both a minimum and maximum bandwidth guarantee and does give priority to this class which is necessary in the case of voice traffic. The "bandwidth" command will give this class a guaranteed mimimum amound of bandwidth. However, keep in mind that these commands only take effect when there is congestion on the link. At other times, the link bandwidth is available for any traffic. Take a look at the following link for further explanation.
http://www.cisco.com/en/US/tech/tk543/tk757/technologies_tech_note09186a0080103eae.shtml
Hope this helps. If so, please rate the post.
Brandon
thanx
We currently have this policy set up.
I am going to add some new routers to our network that will use a policy on the remote side.
Is there any way for me to verify that the new routers are getting their traffic prioritized per the policy if they need to have it prioritized?
You can use the "show policy-map interface" command to see the traffic that is being matched and prioritized such as:
show policy-map interface s0/0
Hope this helps.
Brandon
296
