Community Member
QOS guidance for Voice,Video & data trafic Network Set-up
Hi All,
We have a network set-up for above traffic pattern i.e. AVAYA Ip Telephony, cisco Data Network, IPTV from Televes.
The hardware prospoed is 4507-R ---SUPIIPlus(WS-X4013+) (fully redudant) as core switch, 2960-48PST-L for IPTelephony, 2960G-24TCL
Can you guide us as to what would be an appropriate QOS pattern to be followed in above context to achieve a better performance on our network?
Currently we are prepraing for the configuration phase & need an asisitnce in terms of configuration pattern.
would appreciate if i can get an appropriate docuemnet to further move ahead in the right way for implemenating the QOS inour Network Set-up.
The network envoirnment is for Hospitalty type.
Thx,
M N.
Everyone's tags (1)
1 REPLY
Re: QOS guidance for Voice,Video & data trafic Network Set-up
Since you are in design stages, the right answer is to read the QoS SRND, which will explain the proper design for your environment.
http://www.cisco.com/en/US/partner/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND/QoS-SRND-Book.html
If you have any specific question that that doesn't answer, feel free to post them.
528
