Community Member
qos issue between a vg224 and a 2800 router - weird jitter on fax calls
Have a vg224 and a 2800 router. vg224 has fax machines and 2800 has PRI to PSTN. Fax calls from the vg224 to the PSTN have very high jitter often (400-1200 ms). However, regardless of jitter value the faxes always succeed. (The jitter is a problem because Callmanager ART reports the jitter with a QoS Alert; we are getting false positives making the QoS Alert ineffective).
Strangely, jitter is only reported on the vg224, not the 2800. There are no routers in the mix, everything is plugged into the same switch on the same subnet, QoS configs have been verified by Cisco. No problem jitter coming from anywhere else on the network.
Here is the output of jitter resulting from a "sh call active voice | inc Jitter":
2800
CPRTR01#sh call active voice | inc Jitter
PlayDelayJitter=0
FaxRelayMaxJitterBufDepth = 0 ms
FaxRelayJitterBufOverFlow = 0
vg224
CPRTR03#sh call active voice | inc Jitter
PlayDelayJitter=468
One solution I am thinking about is somehow configuring the vg224 to consider it's leg a fax call the same way the 2800 considers it (you'll notice that the 2800 has a fax relay jitter buffer as well as, I assume, a packetized voice jitter buffer, which may be what accounts for fax success??). Perhaps this is IOS version problem, I don't know.
Configs are attached.
vg224-i6s-mz.124-4.T3.bin
c2800nm-advipservicesk9-mz.124-9.T.bi
Community Member
Re: qos issue between a vg224 and a 2800 router - weird jitter o
so no ideas eh? One thing I forgot to mention is that it is an mgcp to h.323 interworking.
Bronze
First thing I'd do is do a "show controller T1 0/0/0" on the 2800 and look for any clock slips. I don't know if that will cause jitter, but do know that slips will cause problems for faxes.
Community Member
Thanks for your reply. All other phone calls to this gateway experience no undue jitter. The controllers are clean.
Bronze
Also, it looks like the 2800 is configured to use G.729 is the preferred codec, but 14,400 bps is the rate. This might be a problem because G.729's rate is only 8,000 bps.
Both sides are set to prefer T.38 fax relay with Cisco as fallback. That should be fine, but fax relay is designed for networks with high latency or packet loss. Fax Passthrough might be more appropriate for your setup.
364
