Silver
QOS issue
i am having trouble with qos at work. We had one site and everything seems to set up properly but still call quality is not good. This is a I site where they take calls and ans . we check the firewall as well and its not striping any incoming and outgoing packets. DSCP ef making we can see on the packet capture. Any idea?
we use auto Qos
config ..
mls qos map policed-dscp 0 10 18 to 8
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue input bandwidth 70 30
mls qos srr-queue input threshold 1 80 90
mls qos srr-queue input priority-queue 2 bandwidth 30
mls qos srr-queue input cos-map queue 1 threshold 2 3
mls qos srr-queue input cos-map queue 1 threshold 3 6 7
mls qos srr-queue input cos-map queue 2 threshold 1 4
mls qos srr-queue input dscp-map queue 1 threshold 2 24
mls qos srr-queue input dscp-map queue 1 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue input dscp-map queue 1 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue input dscp-map queue 2 threshold 3 46 47
mls qos srr-queue output cos-map queue 1 threshold 3 4 5
mls qos srr-queue output cos-map queue 2 threshold 1 2
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue output dscp-map queue 1 threshold 3 46 47
mls qos srr-queue output dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 2 threshold 1 26 27 28 29 30 31 34 35
mls qos srr-queue output dscp-map queue 2 threshold 1 36 37 38 39
mls qos srr-queue output dscp-map queue 2 threshold 2 24
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue output dscp-map queue 4 threshold 1 8 9 11 13 15
mls qos srr-queue output dscp-map queue 4 threshold 2 10 12 14
mls qos queue-set output 1 threshold 1 100 100 50 200
mls qos queue-set output 1 threshold 2 125 125 100 400
mls qos queue-set output 1 threshold 3 100 100 100 400
mls qos queue-set output 1 threshold 4 60 150 50 200
mls qos queue-set output 1 buffers 15 25 40 20
mls qos
auto qos srnd4
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
class-map match-all AUTOQOS_VOIP_DATA_CLASS
match ip dscp ef
class-map match-all AUTOQOS_DEFAULT_CLASS
match access-group name AUTOQOS-ACL-DEFAULT
class-map match-all AUTOQOS_VOIP_SIGNAL_CLASS
match ip dscp cs3
policy-map AUTOQOS-SRND4-CISCOPHONE-POLICY
class AUTOQOS_VOIP_DATA_CLASS
set dscp ef
police 128000 8000 exceed-action policed-dscp-transmit
class AUTOQOS_VOIP_SIGNAL_CLASS
set dscp cs3
police 32000 8000 exceed-action policed-dscp-transmit
class AUTOQOS_DEFAULT_CLASS
set dscp default
police 10000000 8000 exceed-action policed-dscp-transmit
interface FastEthernet0/24
description DATA+VOICE
switchport access vlan 101
switchport mode access
switchport voice vlan 201
srr-queue bandwidth share 1 30 35 5
priority-queue out
mls qos trust device cisco-phone
mls qos trust cos
snmp trap mac-notification change added
snmp trap mac-notification change removed
no snmp trap link-status
storm-control broadcast level 4.00
storm-control multicast level 10.00
storm-control action shutdown
storm-control action trap
auto qos voip cisco-phone
spanning-tree portfast
spanning-tree bpduguard enable
service-policy input AUTOQOS-SRND4-CISCOPHONE-POLICY
interface GigabitEthernet0/1
description TO:OO_Router_
switchport trunk allowed vlan 101,201,240,250
switchport mode trunk
bandwidth 2000
load-interval 30
media-type rj45
speed 100
duplex full
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust
ip access-list extended AUTOQOS-ACL-DEFAULT
permit ip any any
1 ACCEPTED SOLUTION
Gold
Re: QOS issue
well, data is not as time critical as voice is, and data should not be in a same Expedit queue as voice.
but if thats you want, thats it.
plz Rate if it helped,
Soroush.
Hope it Helps, Soroush.
Gold
Re: QOS issue
Hi there,
what chasis are you using?
It is either mls qos trust cos or service-policy input on a Layer 2 port.
try adding a match for COS 5 under the AUTOQOS_VOIP_DATA_CLASS.
also as for your policy-map is 128K all you want to give to your Voice traffic? how many concurrent voice calls are you handling in your net?
besides: under your service poilcy "AUTOQOS-SRND4-CISCOPHONE-POLICY" you policed the bandwidth and the exceed action is policed-dscp-transmit although you never set any mappings for dscp 46.
plz Rate if it helped.
Soroush.
Silver
Re: QOS issue
Hi thanks Soroush,
we using C2960 Software (C2960-LANBASEK9-M), Version 12.2(55)SE3.
didnt get your poit on "It is either mls qos trust cos or service-policy input on a Layer 2 port."
the funny thing is i cant see any traffic under any interface
sh policy-maP int f0/1
FastEthernet0/1
  Service-policy input: AutoQoS-Police-CiscoPhone
    Class-map: AutoQoS-VoIP-RTP-Trust (match-all)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: ip dscp ef (46)
    Class-map: AutoQoS-VoIP-Control-Trust (match-all)
      0 packets, 0 bytes
      Match: ip dscp cs3 (24) af31 (26)
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      Match: any
        0 packets, 0 bytes
        5 minute rate 0 bps
how can i match =match for COS 5 under the AUTOQOS_VOIP_DATA_CLASS.
i am really new to qos and please advise me how i can set mapping for dscp 46 in service poilcy "AUTOQOS-SRND4-CISCOPHONE-POLICY.
thanks
Silver
Re: QOS issue
we had 1 MB link and there are only 3-4 phones
Green
QOS issue
Amrinder
You are hitting a statistics issue with LAN switches.
The stats will not be the same as you see on a router
From this link for example
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_55_se/configuration/guide/swqos.html
show policy-map [policy-map-name [class class-map-name]]
Display QoS policy maps, which define classification criteria for incoming traffic.
Note Do not use the show policy-map interface privileged EXEC command to display classification information for incoming traffic. The control-plane and interface keywords are not supported, and the statistics shown in the display should be ignored.
This is the same on all IOS release up to the latest 15.0.1SE
Try looking at
show mls qos int f0/1 stat
That will show you which DSCP & COS values are ingressing and egressing the interface
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Gold
Re: QOS issue
Look, what acampbell wrote was for the Show cmnd output, for voice quality, remove the policy-map binding on Fa0/24. you have loads of extra unnecessary qos config there. save a backup of ur current config an try this one.
add these commands for ingress qos:
mls qos srr-queue input threshold 1 50 80
mls qos srr-queue input buffers 60 40
mls qos srr-queue input bandwidth 50 50
mls qos srr-queue input priority-queue 2 bandwidth 20
By default, DSCP values 0-39 and 48-63 are mapped to queue 1 and threshold 1. DSCP values 40-47 are mapped to queue 2 and threshold 1. By default, CoS values 0-4, 6, and 7 are mapped to queue 1 and threshold 1. CoS value 5 is mapped to queue 2 and threshold 1. LEAVE them as it is.
to keep things simple, queueing and threshold in SRR will drop extra packets, so you dont need to police them with a input policy-map.
Egress Queue:
Again here, you set an Expedite queue and configured a whole bunch of CoS/DSCP values as a part of your expedite queue, you dont have to do this, only Voice and critical packets should be in it, CoS 5 and DSCP 46. remove every other values from queue 1.
ALL of these should be off queue 1.
CONFIG:
! set the output buffer for queue 1 (your Voice) 15%
mls qos queue-set output 1 buffers 15 25 30 30
! ONLY map the CoS 5 and DSCP 46 (ef) to queue 1.
mls qos srr-queue output cos-map queue 1 threshold 2 5
mls qos srr-queue output dscp-map queue 1 threshold 2 46
! set the threshold for Queue 1 (ONLY), leave the others as its default.
mls qos queue-set output 1 threshold 1 100 100 100 400
PS: Disable the auto-qos   for test.
Soroush.
Silver
Re: QOS issue
we had some citrix users so we Can’t degrade there data priority?
Gold
Re: QOS issue
Soroush.
Silver
Re: QOS issue
thanks so much for your help.
where do i  use auto qos trust cos and where to use auto qos trust dscp. ?
any idea?
thanks
Gold
Re: QOS issue
well, it depends on your network and how ur equipment work with regards to setting cos or dscp bits on the packets in network. for exmple; if the ip phone use dscp value to prioritize their voice packets, you should trust dscp at the ingress, otherwise use CoS.
finally, CoS is Layer 2 value that's used in trunk encapsulations wherever you have trunk int and DSCP is an IP (L3) parameter.
Soroush.
Re: QOS issue
The configuration we normally use on a Voice gateway for QoS.
class-map match-any Voice-RTP
match ip precedence 5
match ip dscp ef
match ip rtp 16384 16383
class-map match-any Voice-Cntl
match ip precedence 3
match ip dscp af31
match access-group name voice-signal
ip access-list extended voice-signal
permit tcp any any range 2000 2002
permit udp any any eq 2427
permit tcp any any eq 2428
permit tcp any any eq 1720
permit tcp any any range 11000 11999
policy-map QoS-LAN-Policy
class Voice-RTP
set dscp ef
priority 500
class Voice-Cntl
set dscp af31
bandwidth 30
class class-default
fair-queue
Apply it on Voice VLAN interface or towards the WAN interface if you are configuring it between sites:
interface FastEthernet0/1
ip address 10.0.1.1 255.255.255.0
ip rip advertise 2
ip virtual-reassembly
ip tcp adjust-mss 1360
duplex full
speed 100
service-policy output QoS-LAN-Policy
OR
interface GigabitEthernet0/0.105
description *** Voice VLAN ***
encapsulation dot1Q 105
ip address 10.60.x.x 255.255.255.0
h323-gateway voip bind srcaddr 10.60.x.x
Rate this post if helpfull
Green
QOS issue
Hi Omerpal1190.
You are applying a service policy outbound on your interface to the voice gateway router.
Thats OK
But you also need to apply qos for the voip traffic from the gateway on the interface
Depending on the type of switch but lets say a 3750 for example
something like :-
desc *** Link to Voice Gateway ***
ip rip advertise 2
duplex full
speed 100
mls qos trust dscp
srr-queue bandwidth share 1 70 25 5
Alex.
1400
