QoS LAN and WAN
I have received a complain from one of my customer that they have a quality issue in the VoIP calls between two branches.
I  tried to troubleshoot and I found that there is a jitter. while there  is no QoS applied between the branches, I am going to add QoS as below:
Access switches; Configuration:
mls qos
mls qos map cos-dscp 0 8 16 24 32 46 48 56
Access Switches; IP Phones Ports:
mls qos trust device cisco-phone
mls qos trust cos
Access Switches; Trunk interfaces:
mls qos trust dscp
Core switch:
mls qos trust dscp
Router: (LAN Interface)
mls qos trust dscp
Router: (WAN Interface)
interface fast 0/0
bandwidth 2000
auto qos voip
I am sorry if it is silly but this is the first time I am trying to implement QoS.
Everyone's tags (2)
QoS LAN and WAN
No one used QoS before
QoS LAN and WAN
suppose you need policy map on Router: (WAN Interface)
and you need service level agreement with provider
Hall of Fame Super Silver
QoS LAN and WAN
Here is my view on QoS (I use it on all deployments), if you are not comfortable with it you will do more damage than good, In your scenario start out with WAN QoS, you did not specify what WAN connection is in place, is it MPLS, PPP, etc?
If MPLS unless you have contracted for specific real time class with carrier they will not honor your EF markings and in fact drop it.  You need to configure your CE router to match the PE router so this this coordinated effort with the carrier.
If this is PPP, what is the bandwidth between these sites? Typically with links >1.5 Mbps all you need is LLQ configuration.
As to LAN QoS do not use AutoQoS, read Cisco QoS SRND and CUCM SRND for recommadned configuration for your switches, different switches have different queuing mechanisms so there is no one fit all config template. In fact different Line Cards on switches and supervisors will drive different queuing.
HTH,
Chris
QoS LAN and WAN
Hi Chris,
thank you for your reply.
the problem that I have is the following:
Multi-site deployment, all communications between the branches are OK, except one branch where there are too many applications and the speed is 1M, MPLS. The setup in the branch is very simple, it is only one switch and one router.
all what I need is to configure the router to dedicate 100k for VoIP calls.
For Switch I have no issues with QoS configuration. while I have the problem with calls over the WAN all what I need is to trust the marking that I did in the Access switch. To do this I think I need to configure access list to check DSCP values.
Access-list in class-map and the class-map inside policy-map where the policing is configured.
then apply service-policy on the WAN interface.
Please correct me if I am wrong?
Blue
QoS LAN and WAN
Best document we have is QOS SRND. This has sample config also.
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND/QoS-SRND-Book.html
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
QoS LAN and WAN
Thank you Ronak,
I am browsing the document, please if you have any notes on what I added now (in response to Chris Deren) please let me know.
+5 for you and Chris.
QoS LAN and WAN
after some studying, this is what I think the correct solution:
Access switches:
mls qos
IP Phones Ports:
mls qos trust cos
Trunk interfaces:
mls qos trust dscp
Router:
class-map match-any VoIP-RTP
   match ip dscp ef
class-map match-any VoIP-Control
   match ip dscp cs3
   match ip dscp af31
policy-map VoIP-Policy
   class VoIP-RTP
       priority percent 10 ! It is 1M link and I need to dedicate 100 K
class VoIP-Control
   bandwidth percent 5
class class-default
   fair-queue
interface Gig 0/0
description To Service provider
bandwidth 1000 ! it is 1M link
service-policy output VoIP-Policy
Please if anyone has any suggestion or if I am wrong please correct me.
QoS LAN and WAN
This should be fine for what you are trying to do.
Chris
QoS LAN and WAN
Thanks Chris,
Just to make sure that you toke care about the following:
priority percent 10
bandwidth 1000
! it is 1M link
thanks in advanced
QoS LAN and WAN
Yes, badwidth statement is in kbps, so 1000 -- > 10 Mb.
You can issue "sh policy-map interface x/x" which will actually show you the bandwidth.
Chris
QoS LAN and WAN
                                                           1000 --> 1 M
Am I right?
and regarding the command:
priority percent 10
depending on the bandwidth command under the interface, true??
QoS LAN and WAN
Correct, this is actually the preferred method.
Chris
QoS LAN and WAN
Thank you too much, I will try the configuration and let you know.
QoS LAN and WAN
here u need 1 parent policy and 1 child police
like this
policy-map child
class one
  priority 50
  set precedence 3
class two
  priority 156
  set precedence 3
class three
  priority 280
  set precedence 3
class Cl_ICMP
  shape average 10000
class voice
  priority 100
  set precedence 5
class class-default
policy-map parent
class class-default
  shape average 1000000
  service-policy child
and more impotant
is ageement with provider
where provider must give you
for example 10% real time traffic
1818
