QoS on 3560, 2960 and 3750 does not work (Policy-map).
I am tryng to configure QoS on 3 switches (2960, 3560 and 3750) with this configuration:
mls qos
class-map match-all QOS_DATA_CLASS
  match access-group name QOS-DATA
class-map match-all QOS_DEFAULT_CLASS
  match access-group name QOS-DEFAULT
class-map match-all QOS_VOICE_CLASS
  match access-group name QOS-VOICE
class-map match-all QOS_SIGNALING_CLASS
  match access-group name QOS-SIGNALING
policy-map QOS-SOFTPHONE-POLICY
 class QOS_DEFAULT_CLASS
   set dscp default
 class QOS_SIGNALING_CLASS
   set dscp cs2
 class QOS_DATA_CLASS
   set dscp cs1
 class QOS_VOICE_CLASS
   set dscp cs3
interface GigabitEthernet0/34
 no switchport
 ip address 10.10.11.1 255.255.255.252
 ip ospf network point-to-point
 priority-queue out
 service-policy input QOS-SOFTPHONE-POLICY
interface GigabitEthernet0/47
 switchport access vlan 150
 spanning-tree portfast
ip access-list extended QOS-DATA
 permit tcp any any eq 22
 permit tcp any any eq 465
 permit tcp any any eq 143
 permit tcp any any eq 993
 permit tcp any any eq 995
 permit tcp any any eq 1914
 permit tcp any any eq ftp
 permit tcp any any eq ftp-data
 permit tcp any any eq smtp
 permit tcp any any eq pop3
ip access-list extended QOS-DEFAULT
 permit ip any any
ip access-list extended QOS-SIGNALING
 permit tcp any any range 2000 2002
 permit tcp any any range 5060 5061
 permit udp any any range 5060 5061
ip access-list extended QOS-VOICE
 permit udp any any range 16384 32767
but when I check the show commands I see that QoS is not working.
CoreA#sh policy-map interface g0/34
 GigabitEthernet0/34
  Service-policy input: QOS-SOFTPHONE-POLICY
    Class-map: QOS_DEFAULT_CLASS (match-all)
      3 packets, 198 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: access-group name QOS-DEFAULT
    Class-map: QOS_SIGNALING_CLASS (match-all)
      0 packets, 0 bytes
      Match: access-group name QOS-SIGNALING
    Class-map: QOS_DATA_CLASS (match-all)
      0 packets, 0 bytes
      Match: access-group name QOS-DATA
    Class-map: QOS_VOICE_CLASS (match-all)
      0 packets, 0 bytes
      Match: access-group name QOS-VOICE
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      Match: any
CoreA#sh policy-map interface g0/47
 GigabitEthernet0/47
      0 packets, 0 bytes
      0 packets, 0 bytes
      0 packets, 0 bytes
      0 packets, 0 bytes
      0 packets, 0 bytes
      Match: any
What do I do bad?
The flow is the next:
Computer with CIPC --------> Switch 2960 or 3560 or 3750 ------------------> switch core ---------------> CIPC
I have wireshark in a port mirror on switch 2960, 3560 and 3750. In wireshark I always see the packets marked with default label.
I hope you can help me.
Regards.
Everyone's tags (6)
Please, see this post: https:
Please, see this post: https://supportforums.cisco.com/discussion/11079636/c2960s-qos
The show policy-map interface doesn't work on these switches.
Regards.
Hi DanieleThanks for your
Hi Daniele
Thanks for your help, I understand that but why when I use Wireshark in a span port on switches all packets are marked with default label?
Regards.
Try this config: policy-map
Try this config:
   set dscp cs3
   set dscp cs2
   set dscp cs1
 class class-default
   set dscp default
BR
631
